Trying to remove rear brake disc so I won’t damage it when replacing wheel bearings. Any suggestions on how to remove chrome bolt caps? Can’t seem to get a screwdriver in there to pry them up, and don’t want to damage disc.
It’s a chrome cap that covers the bolt that holds the brake disc. There are 4 bolts and four caps. The manual says to remove them, but not how to. Looks like they are pressed on.
I'd consider leaving the rotor on if possible, but I haven't replaced wheel bearings so I don't know if that is feasible. Those bolts are hard to get out, and will have to be replaced.
I don't have those caps, but obviously the only way to get them off is to pry them off.
Those are the same as the plastic caps in my photo. I don't have them either, but are common used to finish cap screws. They are a push fit. Shouldnt really be a problem removing them. You will mess them up a little and should be able to shove a flat bladed screwdriver in there with out contacting the disc. They are relevantly not expensive to replace with new ones or just reuse them.
Hope you dont mind me saying, but I do wonder if you are having troubles with these caps if you have the tools required and the necessary wrenching knowledge to swap out the wheel bearings.
Hard to tell from photo, but disc looks scored. If so you should seriously consider replacing along with new pads. Otherwise you will progressively impair braking efficiency.
I picked up a set of picks (like those used by dentists). Amazing how many times they have been useful tools. Try them if still looking to remove the caps. Used on my handlebar risers successfully. While the caps are cosmetic, they do keep the allen bolt head recesses clean.
Yes, thanks. I’m replacing that, too. It was badly messed up.
Related Threads
Triumph Rat Motorcycle Forums
3.9M posts
167.7K members
Since 2002
