18" wide rims on Bonneville SE - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
 5Likes
post #11 of 22 (permalink) Old 08-20-2018, 01:46 AM
Main Motorcycle: 2015 Bonneville SE Custom
Originally Posted by dUb-T120 View Post
Hey Ripp - I see you're in LA. Head over to Canyon and check it out in person. They're the ones doing these wheel mods. Solid dudes for sure.
https://goo.gl/maps/YBEEe5fDk6x
Thanks for rec man! I’ve been to their shop before when I owned my thruxton. Bought some parts from him and talked shop. He’s super nice. I even sent an email to him recently about the direct swap spoke wheel kit he offers for se’s. We ended up talking on the phone a bit about what he offers. With this kit, no modifications are needed to change an se from mag to spoke wheel except for replacing the stock se front brake rotor with one from a t100. Otherwise it’s plug and play. However it costs an arm and a leg.
If I can pick up stock t100 hubs for cheap and machine my own spacers then I’m fine with that.
The stock hubs might be “heavier” than the ones canyons offers but I’m not really looking for performance. I’m just looking for that classic look.
Even though this thread is about fitting wide wheel canyon kit on an se, the theory is the same as fitting stock hubs on an se since the hubs are the same widths. This is why I’m so intrigued and have so many questions.
dUb-T120 likes this.
RippNSh!t is offline
post #12 of 22 (permalink) Old 08-20-2018, 03:58 PM Thread Starter
Main Motorcycle: 2012 Bonneville SE
Originally Posted by rodhotter View Post
they look good!! i see you have the british customs exhaust, i think. got a similar one as i hope to add a sidecar i got + having the pipes exit + sound opposite the chair is a plus.
Thanks, These pipes are pretty loud. The person who owned my SE before me put them on but ignored the part where they would be too low for the SE. So i do have some evident grinding marks on the headers from hitting the ground while cornering. I've since raised up the suspension a bit so that isn't an issue anymore.
Jeff
Synigod is offline
post #13 of 22 (permalink) Old 08-20-2018, 04:20 PM Thread Starter
Originally Posted by plodalong View Post
In isolation the mag wheels look ok but with the spokes it looks superb.
Yeah i think it looks good on either rimset but the spokes make me smile a little more.
Originally Posted by speedfoos View Post
Looks great!
For your safety though, if that's still the same rubber, please be careful coming out of the hole on corners. The Marathon 880s that were on the wheels are like ice skates without the edge to push off from.
It is the same rubber, I've felt them slide a little but I'm not super aggressive while riding. I'll keep it in mind though. Thanks for the warning.
Originally Posted by Mcharn View Post
How much did the handling change when you switched out the mag wheels? Was there a significant increase in seat height as well?
Going from 17" front rim to the 18" front rim wasn't much of a change. I could tell the front rim didn't counter-steer as fast but I like the stability from the larger patch of tire contacting the ground. It also helps that I put ohlins cartridges in the front. I am still in the process of getting used to the bike with all the upgrades I put on. Once I have more non straight line miles on it, I will let you know
Originally Posted by RippNSh!t View Post
man this looks so good! congrats. this is my dream. i really dont like that mags. but i do like how yours were all black. did you paint or powder coat them? maybe ill do the same to mine in the interim...
thanks for this info. theres not much out there thats very descriptive on how to do this swap.
i would love to see images of the spacers for hubs and caliper if you have a minutes to take a few?
also are both front and rear spoke rims 18" ? thats good to know that youre still able to fit an 18" rim and tire under the stock se fork brace. i was concerned with that for sure
and lastly how long are your rear shocks? they look about .5-1inch longer than stock but maybe that's an optical illusion created by your choice of seat?
your bike looks great! looks way better with these spokes rims!
Thanks! I like the all black mag wheels much better than the stock color. I had them powder coated after I was in an accident and I purchased the motorcycle back from the insurance company. I did all the leg work on removing the tires, bearings and seals. It was about 300 for both rims from a local powder coating company. The new bearings/seals cost about 100ish. Reassembly was pretty straight forward and then getting the tires balances cost was about 40 bucks from my local honda motorcycle dealership. In all it was about 350-400 for just the powder coating but I also added the galfer rotor on the front which I think looks awesome! I am selling my powder coated rims if you are interested. If not, that's okay too
Both front and rear are 18" I liked that the front and rear are the same size vs the off set sizes of the T100. Just my personal preference
My rear shocks are about 360mm eye to eye. I really want to get some ohlins for the back to round our my setup but they are soooooo expensive. Also my front suspension is a little different. Since i have ohlins cartridges installed i had to have my shock length be about an inch longer so the cartridges would fit. Basically I have scrambler tubes with SE lowers. Yes it is a bit weird but it works and looks good too.
Originally Posted by 180q View Post
Great upgrade, they look awesome. I'm jealous for sure.
Thanks, I got a good price from Speedfoos which helped convince myself I can spend the money without my wife chopping off my head. It helped a lot to have my own machine shop at work to be able to make the spacers. Also my father who is an ex motorcycle mechanic helped a lot too.
Synigod is offline
post #14 of 22 (permalink) Old 08-20-2018, 04:24 PM Thread Starter
Thanks for rec man! Iíve been to their shop before when I owned my thruxton. Bought some parts from him and talked shop. Heís super nice. I even sent an email to him recently about the direct swap spoke wheel kit he offers for seís. We ended up talking on the phone a bit about what he offers. With this kit, no modifications are needed to change an se from mag to spoke wheel except for replacing the stock se front brake rotor with one from a t100. Otherwise itís plug and play. However it costs an arm and a leg.
If I can pick up stock t100 hubs for cheap and machine my own spacers then Iím fine with that.
The stock hubs might be ďheavierĒ than the ones canyons offers but Iím not really looking for performance. Iím just looking for that classic look.
Even though this thread is about fitting wide wheel canyon kit on an se, the theory is the same as fitting stock hubs on an se since the hubs are the same widths. This is why Iím so intrigued and have so many questions.
I will post the sizes of the spacers with some pictures tonight. If you have a machine shop then it will be much easier. I may be able to help if you don't have access to a machine shop Also I am always up for answering questions, so ask away. Plus it can be a good thing for other people who have the same questions.
Jeff
Synigod is offline
post #15 of 22 (permalink) Old 08-21-2018, 11:01 AM
Main Motorcycle: 2014 Mag wheel
chops717's Avatar
The new wheels look good, but seeing your mags makes me want to powder coat mine even more now
chops717 is offline
post #16 of 22 (permalink) Old 08-21-2018, 02:43 PM
i agree. seeing the all black mags makes me want to do the same. i would def do this as personally the all black makes the mags more tolerable. but i think i have a few leads on some spoke wheel options.....
post #17 of 22 (permalink) Old 08-21-2018, 02:47 PM
so heres a third option to a mag wheel to spoke wheel conversion (which is looking like the cheapest and most streamlined effort):
1) find rear hub for t100/thruxton/scrambler including kush drive. swap over sprocket and rear brake rotor ( personally i would upgrade the stock 17" rim to an 18" and put on new tires)
2) purchase the direct bolt on hub mag wheel to spoke wheel conversion by canyon motorcycles (upgrade brake rotor to t100 size, rim size 18" and put on new tires). this way no spacers are needed nor replacing triple trees.
it looks like this is going to be my route....
post #18 of 22 (permalink) Old 08-21-2018, 03:10 PM Thread Starter
Thanks! I am honestly torn between the two. I love them both.
Synigod is offline
post #19 of 22 (permalink) Old 08-21-2018, 03:15 PM Thread Starter
This seems like a nice low cost option. I look forward to seeing the pictures!
Synigod is offline
post #20 of 22 (permalink) Old 08-22-2018, 05:32 PM
so i spoke to adrian at canyon motorcycles. hes willing to build me a direct bolt on spoke wheel to convert my se mag wheel. however its still going to cost quite a bit.
i found someone who will build me a wheel using a talon hub, offset to compensate for the se brake caliper, and includes new spacers. still waiting to hear price for this build but im going to predict its cheaper than canyon motorcycles. will give an update on what i discover...
oh and i should mention that i was able to find a stock t100 rear hub for pennies on ebay. its currently in the mail and will end up purchasing a rim and spokes from buchannans as they are in my backyard.
Swapping Mid-Control to Rearsets on Bonneville. ZMBSNPR Air Cooled Twins Technical Talk 7 10-14-2016 10:25 AM
2016 Triumph Bonneville: Spy Shots Halfpint News Room - Homepage 37 05-19-2016 07:23 AM
Los Angeles to Vancouver on a Bonneville deadhand Air Cooled Twins Talk 26 09-02-2015 03:24 PM
