Slight bump from behind while parked - Triumph Forum: Triumph Rat Motorcycle Forums
 7Likes
post #1 of 11 (permalink) Old 06-22-2018, 05:42 PM Thread Starter
A very sheepish coworker just let me know that he bumped my '12 T100 in the office parking lot. Didn't knock it over thankfully.
It was parked in first gear, and from the drag mark under the side stand, it looks like it was pushed forward about six inches. I put it in neutral and it rolls back and forth normally.
I doubt it did any mechanical damage, but has anyone known of something bad happening from a bike being forcefully pushed a bit in gear?
Cosmetically, it just kinked my rear fender slightly. I have a friend in the paintless dent removal business who will take a look at it.
Lone Commuter of the Apocalypse
2012 Bonneville T100
2013 Honda CB1100
Gone in 60 is offline
post #2 of 11 (permalink) Old 06-22-2018, 05:54 PM
Main Motorcycle: 2014 T-Bird Storm
deaconblues's Avatar
Since bikes are pretty light, it probably just shoved the rear tire forward without rotating it. But, you should have it looked at by your mechanic, just to make sure the hit didn't bung up any swingarm bushings or suspension mounts. You may also want to check to see if your rear wheel is still aligned, if the wheel/tire itself got hit.
Current: 2014 Triumph Thunderbird Storm "Rockabilly"
Past: '79 Yamaha XS750 "Cerberus" | '87 Yamaha FZ700 "Pandora" | '92 BMW K75/RT "Sif" | '08 Triumph Sprint 1050 ST "Sapphire Strumpet"
I'm not just leaning the bike, I'm tilting the world.
deaconblues is offline
post #3 of 11 (permalink) Old 06-22-2018, 09:39 PM Thread Starter
Good idea. I've got a 20 mile ride home, and will see if anything feels weird, and give it a good going over. Good point about rear wheel alignment. I'll put my laser guide on it, most likely not, since the fender took the push, not the wheel, and doesn't look like the fender hit the wheel.
2013 Honda CB1100
post #4 of 11 (permalink) Old 06-22-2018, 10:02 PM
Main Motorcycle: 2014 Triumph Bonnie
Other Motorcycle: 1970 Bonnie
I hit my own bike strait on from the rear fender and knocked the bike 15 feet, did a lot of cosmetic damage but didnt knock the wheel out of line, didnt damage any bearings, bushings ......... I cant imagine a six inch shove, even in gear, would do much damage other then the obvious fender crunch that you see, but sure, you should check everything out just to make certain.
DougAU is offline
post #5 of 11 (permalink) Old 06-22-2018, 10:06 PM
I have push started a few bikes in my time. I have never done it in first gear as the compression stops the wheel rotating. Therefore I would guess the wheel just slid. If it did grip and rotate no damage would be done. Think about how much force goes through the drive train each time you down shift.
I we think about this a bit more, the forces involved to slide a bike forwards are very low compared to hard breaking from 100 Km/H or doing a wheelstand. I could not see any way you would damage a bike by sliding it on a hard surface whilst upright. Otherwise bikes would be getting damaged every day whilst being riddern and a small slide occurs.
Steve
hickslawns and 777 like this.
reidy41 is offline
post #6 of 11 (permalink) Old 06-23-2018, 04:24 AM
Main Motorcycle: Triumph Bonneville SE
mick 85's Avatar
Touch up the rear fender and thank your co - worker for being so honest. Job done.
Back2-2 likes this.
Born to be mild
mick 85 is offline
post #7 of 11 (permalink) Old 06-23-2018, 07:41 PM
Main Motorcycle: 01 Triumph Bonneville
Other Motorcycle: 01 HD Night Train
Extra Motorcycle: 87 Honda Super Magna
At least told you...its the sign of an honest man
hickslawns likes this.
Arrow 2-2...Unrestricted Air box with K&N and TTP Breathe 140 mains with 42 pilots 2 shims
DUCKMAN is offline
post #8 of 11 (permalink) Old 06-23-2018, 09:47 PM
Main Motorcycle: Bonnie Newchurch
Harpeaux's Avatar
Other Motorcycle: CRF250L
This is just the excuse you need to get that FEK youíve been lusting after!
Harpeaux is offline
post #9 of 11 (permalink) Old 06-24-2018, 11:22 AM Thread Starter
Speaking of eliminator kits, there are usually several fenders for sale on my local Craig’s List at any given time. Right now nothing in my color. I like the original look, but was thinking about getting rid of it for a while. Checked everything, it rides fine.
My coworker still feels bad. I mentioned that a bottle of MaCallan single malt might make me feel better.
2013 Honda CB1100
post #10 of 11 (permalink) Old 06-30-2018, 01:51 PM
Indeed!!
Also, be thankful that it didn't flip the sidestand back and drop the bike.
Front end wobble after massive bump Fazetwo Air Cooled Twins Talk 10 06-18-2018 08:10 PM
Slight oil traces under the clucth lever satztg Street Triple Forum 2 11-29-2017 10:11 PM
Street triple cranks, does not start, but bump starts dutchbike Street Triple Forum 107 10-23-2017 09:59 PM
Slight Surging - 2007 America ChrisonTop Cruisers - America, Speedmaster 5 09-24-2017 05:33 PM
Slight clunk clunk sound when pulling away Mark444 Speed Triple Forum 18 03-17-2017 12:03 PM
