What if I didn't pre-fill the new oil filter? - Page 5 - Triumph Forum: Triumph Rat Motorcycle Forums
 26Likes
post #41 of 60 (permalink) Old 05-11-2018, 11:25 AM
Main Motorcycle: 2006 Triumph Sprint ST
On the first oil change on my new-to-me 2006 Sprint ST I failed to fill the oil filter and let it drain for a long time. Replacing the filter and filling with the specified amount oil, on starting the oil pressure light would not go out. Tried it three times, removed the dip stick, tried a "burp", but still had an oil light. Finally dropped the oil filter that appeared about half full. Filled it with oil, reinstalled, started, and almost immediately the oil pressure light went out.
So either it took a long time for oil to fill the system from the pump or pre-filling the filter makes a difference.
The manual calls for pre-filling.
Gostowski is offline
post #42 of 60 (permalink) Old 05-11-2018, 11:40 AM
Main Motorcycle: 2012 Bonneville SE
sparky57's Avatar
"So here's another thing that's come up -- literally. After my oil and filter change, I idled the bike for 30 seconds or so. Waited a while and checked my level. Added another half-litre (half-quart, approx) or so to get it up between the markings on the case. That made it four litres, in all.
I get back from a one-hour ride, put the bike back up on its centre stand -- and now I'm significantly over the proper level. Well above the lines, but still within the sight glass.
How the heck does that happen? And is it significant enough to try to siphon out some of the excess?"
That's happened to me too.
sparky57 is offline
post #43 of 60 (permalink) Old 05-11-2018, 11:54 AM
Main Motorcycle: '09 T100 EFi
lambroving's Avatar
Other Motorcycle: Monster 796 ABS "Pantah"
Extra Motorcycle: K100RS 16/ABS
Total capacity with a complete drain and filter change is 4 US Qts. Excess "may" end up in your air box.
'09 T-100 Forest Green / New England White, TORs, Intiminators & fork tubes raised 15mm, Chrome Ikon 7610 - SP8 Shocks, Custom Sargent Saddle, OEM Chrome Grab Rail, Conti Road Attack 2 EVO's 110/80VR19 & 150/70VR17, 7" Cibie lens and uprated H4 bulb.
lambroving is online now
post #44 of 60 (permalink) Old 05-11-2018, 04:13 PM
Main Motorcycle: '14 Bonneville T100
Location: Wilmington, NC - Winter, Downeast Maine - Summer
Other Motorcycle: '13 Street Triple
Extra Motorcycle: '07 Honda 919
There are a whole lot of bikes that have horizontal oil filters. (Hondas for example) There is no way to "pre-fill" those filters without having the oil run out out the ground before you can get it screwed on. I'm not aware of any big issue with Honda engines failing due to oil filters not being pre-filled. I have 2 Hondas with horizontal oil filters and both engines are just fine.
As an aside, I worked for a large car company before I retired. At one point, I was having an issue with very slow oil pickup after parking my vehicle after parking overnight on a downhill incline. I asked the manager of engine development about this an whether I was ruining the engine by letting it idle for 15 or 20 seconds before the oil pressure came up. He told me that any decent engine (mine included) could run for 10 or 15 minutes at idle with no oil pressure. Not to worry!! But remember, this is at idle!!
Doberperson is offline
post #45 of 60 (permalink) Old 05-11-2018, 04:17 PM
cadd's Avatar
Now the question is: do professional mechanics fill the filter before spinning it back on when you bring your bike/car in for an oil change? I'm pretty certain they don't. I'll be lucky if they rub a little used oil on the filter's o-ring before spinning in on.
Riding it like I financed it.
cadd is offline
post #46 of 60 (permalink) Old 05-11-2018, 05:21 PM
knifemaker's Avatar
^ So you just said that "professional mechanics" likely may not even put oil on the o-ring. So them not pre-filling a filter would be expected.
I had a "professional mechanic" forget to put oil in my bike when I took it in for its first oil change.
I think the bottom line here is if you can pre-fill your filter (without making a mess) it likely makes some sense. Will it really make any difference if you don't? Perhaps not, but if the manual says to, I'm gonna do it.
geb likes this.
knifemaker is offline
post #47 of 60 (permalink) Old 05-11-2018, 08:47 PM
Main Motorcycle: 2007 Bonnie T100
bonza's Avatar
Other Motorcycle: Jeep Wrangler
most don't because they have a tight schedule with lots of jobs lined up ahead and can't be fagged poonsing around pre-filling an oil filter. they tend to drain the oil, remove the filter, refit the sump plug, refit a new filter then re-fill the sump with oil. all done fairly quickly within ten minutes, so there would be residual oil coating all the internals parts anyway
does it make a difference? probably not in the short term, maybe after a couple of hundred thousand kilometers there maybe a measurable difference
as I do all my own maintenance I tend to drain and remove the filter then poonse around scratching my backside etc, have a cuppa, then a few hours later finish off with a pre-filled oil filter
Forchetto, geb and Kylemason like this.
2007 Tuxedo T100.
Dom Tourers, TTP breathe, DNA filter,baffle gone, 40/140/1 shim 3 turns, TTP igniter tune, Hagon Nitros, Thruxton Bars, Halcyon bar end mirrors, Pingel fuel valve, Monza gas cap, Burton seat, Avon Roadriders
bonza is offline
post #48 of 60 (permalink) Old 05-11-2018, 11:35 PM
Main Motorcycle: '02 Triumph Bonneville
LapinAgile's Avatar
So, just to sum up for clarity, regardless of using either the Haynes or the Triumph Service manual, the poonsing should occur before pre-filling the filter?
bheezy27403, mick 85 and Kylemason like this.
'02 Bonneville - AI removed, 152MJ's, 42's 1.5 turns out, Air Box Gone/Uni Filters, TPS removed/capped, NH Togas, Nology Coil, Hotwire plug wires, TTP SafeStart, TTP Firestarter, D9 Bracket, Pingel petcock, 19 tooth sprocket, Michelin Pilot Actives.
LapinAgile is online now
post #49 of 60 (permalink) Old 05-12-2018, 05:25 AM
bonza's Avatar
yep
2007 Tuxedo T100.
bonza is offline
post #50 of 60 (permalink) Old 05-12-2018, 05:36 AM
Main Motorcycle: 2019 Speed Twin
Kinjane's Avatar
...even a downside up filter can be pre-soaked
geb likes this.
Whenever I see a bike advertised with 'a shed load of extras' I often wonder how well it handled with a deckchair, lawnmower, some hose and a rake strapped to it.
Kinjane is offline
K&N Oil Filter Mishap- Oil Filler Cap Offensivemotor Air Cooled Twins Talk 72 06-24-2018 12:49 AM
Need Oil and Filter ADVICE PLEASE norton828 Air Cooled Twins Technical Talk 20 01-31-2018 09:19 PM
A few newb questions: Mr.Dudecool Classic, Vintage & Veteran 17 08-13-2015 02:34 AM
oil weeping from oil fill cap dilawn Street Triple Forum 13 06-24-2015 06:41 AM
multiple punch marks on crankshaft - this a problem? jonkster Classic, Vintage & Veteran 186 03-12-2015 08:00 PM
