What if I didn't pre-fill the new oil filter? - Page 4 - Triumph Forum: Triumph Rat Motorcycle Forums
 26Likes
post #31 of 60 (permalink) Old 05-10-2018, 12:39 PM
Main Motorcycle: Tiger 955i 2006.
Other Motorcycle: Yamaha FJ1200 1987
I wonder if they are pre-filled on the production line?
That first push of the starter button must be the most wearing of all.
Steve999 is offline
post #32 of 60 (permalink) Old 05-10-2018, 12:59 PM
Main Motorcycle: 2014 Bonneville T100
Probably right. I had a friend who installed a pre-luber on his car. It was a button you would hit before you started the car that activated a pump that gave that car oil pressure before you started it. I know with the car engines that I have built that we prime them before first start by taking out the distributor and running the oil pump with a drill.
Chada is online now
post #33 of 60 (permalink) Old 05-10-2018, 01:03 PM
Main Motorcycle: '09 T100 EFi
lambroving's Avatar
Other Motorcycle: Monster 796 ABS "Pantah"
Extra Motorcycle: K100RS 16/ABS
Originally Posted by cadd View Post
I agree completely. I want to see someone fill this filter before spinning it on.
I'm reminded of numerous vintage Ferraris which had two massive red filters inverted and staring you in the face. Those probably didn't starve the oil pump for flow however and might be considerably downstream. Might have known at one time but currently plead Halfsheimers.
'09 T-100 Forest Green / New England White, TORs, Intiminators & fork tubes raised 15mm, Chrome Ikon 7610 - SP8 Shocks, Custom Sargent Saddle, OEM Chrome Grab Rail, Conti Road Attack 2 EVO's 110/80VR19 & 150/70VR17, 7" Cibie lens and uprated H4 bulb.
lambroving is online now
post #34 of 60 (permalink) Old 05-10-2018, 01:07 PM
lambroving's Avatar
On certain vehicles I used to sell and two which I still own, the starter must crank above 750 RPM for a few seconds before the ECU allows firing.
post #35 of 60 (permalink) Old 05-10-2018, 01:50 PM
That's a very cool feature.
Chada is online now
post #36 of 60 (permalink) Old 05-10-2018, 02:22 PM
Main Motorcycle: '03 Bonneville T100
coachconnor's Avatar
Other Motorcycle: 74 Honda 450 long gone
One could always pull the spark plug leads and spin it over for about 20 secs. two or three times. No real engine load and the filter will be filled. Had a friend with a filter which was opening side down (like Ferraris). He did it that way every oil change. I fill mine but it's not a big deal. Not replacing the drain plug or forgetting oil: very big deal.
19t, BC Sleepers, 42 pilots, Thrux needles & springs, 135 mains, K&N, Dart screen, air box bafflectomy, Barnett greens, TEC shocks
Wonderous apparitions - provided by magicians. J Fogerty
coachconnor is offline
post #37 of 60 (permalink) Old 05-10-2018, 02:36 PM
lambroving's Avatar
Guess those G-DEC engineers weren't so dumb. https://goo.gl/maps/LGc5WVjwrtK2
Could only be an issue if the battery were VERY low. Some earlier vehicles had a manual override for another purpose, but you'd need long arms to press that button under the seat while turning the key!
Bonnevilles should come standard with that button so that we wouldn't need Dr. F's low voltage shortcut..., but the product liability lawyers would have a field day...
post #38 of 60 (permalink) Old 05-10-2018, 02:40 PM
lambroving's Avatar
Unless you know for sure otherwise, would not like to try that unless the leads were grounded. Many electronic ignitions have been fried that way!
post #39 of 60 (permalink) Old 05-10-2018, 04:58 PM
Main Motorcycle: 2012 Bonneville
knifemaker's Avatar
I usually prefill. I mean, it's not like it's that hard, you got the oil and the filter right there...
I had a Vulcan 750. These bikes were notorious for having the oil light not go out because you didn't pre fill the filter. Folks found if they "burped" the filter...(loosen it up a bit and then tighten it back while the bike was running) fixed the issue if they didn't pre-fill.
Didn't make sense to me, but it worked.
knifemaker is online now
post #40 of 60 (permalink) Old 05-10-2018, 05:32 PM
Main Motorcycle: 2006 Bonneville T100
road dog's Avatar
Other Motorcycle: 2002 ThunderBird 900
Extra Motorcycle: 1982 CB900F SuperSport
I rarely remember to actually do that...
but I've never worried about forgetting.
LapinAgile likes this.
road dog is offline
K&N Oil Filter Mishap- Oil Filler Cap Offensivemotor Air Cooled Twins Talk 72 06-24-2018 12:49 AM
Need Oil and Filter ADVICE PLEASE norton828 Air Cooled Twins Technical Talk 20 01-31-2018 09:19 PM
A few newb questions: Mr.Dudecool Classic, Vintage & Veteran 17 08-13-2015 02:34 AM
oil weeping from oil fill cap dilawn Street Triple Forum 13 06-24-2015 06:41 AM
multiple punch marks on crankshaft - this a problem? jonkster Classic, Vintage & Veteran 186 03-12-2015 08:00 PM
