What if I didn't pre-fill the new oil filter? - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
 26Likes
LinkBack Thread Tools
Old 05-08-2018, 03:59 PM
Main Motorcycle: '02 Triumph Bonneville
LapinAgile's Avatar
Originally Posted by triumph rookie View Post
Ah, but that is incorrect, sir. That is exactly what the owner's manual says to do. Which is the only reason I do it. Have never done it with any other vehicle.
So here's another thing that's come up -- literally. After my oil and filter change, I idled the bike for 30 seconds or so. Waited a while and checked my level. Added another half-litre (half-quart, approx) or so to get it up between the markings on the case. That made it four litres, in all.
I get back from a one-hour ride, put the bike back up on its centre stand -- and now I'm significantly over the proper level. Well above the lines, but still within the sight glass.
How the heck does that happen? And is it significant enough to try to siphon out some of the excess?
You're likely a bit overfilled, but whether that's critical you air filter will tell you shortly. I 'sometimes' pre-fill the filter, but don't consider it crucial. The only time I put in 4 liters was after I'd had the clutch cover off for some days, allowing I suspect every drop to drain out. Otherwise, unscientifically, there's always some inch + a half left in the last bottle.
Baltobonneville likes this.
'02 Bonneville - AI removed, 152MJ's, 42's 1.5 turns out, Air Box Gone/Uni Filters, TPS removed/capped, NH Togas, Nology Coil, Hotwire plug wires, TTP SafeStart, TTP Firestarter, D9 Bracket, Pingel petcock, 19 tooth sprocket, Michelin Pilot Actives.
LapinAgile is online now
Old 05-09-2018, 09:25 AM
Main Motorcycle: 01 Triumph Bonneville
Other Motorcycle: 01 HD Night Train
Extra Motorcycle: 87 Honda Super Magna
It is a myth that you need to put oil in the filter.
Arrow 2-2...Unrestricted Air box with K&N and TTP Breathe 140 mains with 42 pilots 2 shims
DUCKMAN is online now
Old 05-09-2018, 01:59 PM
Supernova
Forchetto's Avatar
From page 9.11 of the 2012 Service manual:
"Apply a smear of clean engine oil to the seal of the new filter and fill the filter with clean engine oil."
"Befehl ist Befehl" (Only following orders)...
Forchetto is offline
Old 05-09-2018, 02:12 PM
Main Motorcycle: 2018 Tiger 800 XRx Low
Other Motorcycle: 2013 Street Triple R
Extra Motorcycle: 2019 Z900RS Café
I don’t wanna start anything, LOL, but on every vehicle I own... besides not pre filling the filter, I let drain to the last drop and then fill to the EXACT capacity on the manual. No “fill that less amount, run, check again, top off” and I’ll be damned that when checking, every single time I’m right at the edge of the top line level, to the point I don’t even bother to check after filling anymore, unless it’s a first oil change on a new to me vehicle. What is the point of filling some amount, checking, topping off? I don’t get it. The manual states the capacity.
Evangelos K is offline
Old 05-09-2018, 04:01 PM
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: 2014 Ninja 1000ABS
That's assuming you can get the assumed amount of used oil out from the engine. Do whatever works for you. I had a Dodge Dakota that I could only get out 2.5 qts out of 5 capacity. Quick lube shops were always overfilling my engine so I stopped going. They just went by the specs as well.
Felony is online now
Old 05-09-2018, 07:38 PM Thread Starter
Main Motorcycle: 2010 Bonneville T-100
triumph rookie's Avatar
Other Motorcycle: 1980 Honda CM400 (RIP)
Don't worry, EK, it's already started
BonnieBlack and Evangelos K like this.
AI, O2 and air box baffle removed, BC Sleeper Pros, Breathe and tune from TTP, polished cups from D9, Triumph bar-end mirrors, centre stand, other goodies.
"Nowadays I got me two good wheels, and I seek refuge in aluminum and steel." S. Earle
triumph rookie is offline
Old 05-10-2018, 09:03 AM
From the same people whose apparel come with label that states "Must be installed by Qualified Technician". The oil on the seal is needed...filling the filter isnt. Many motor vehicle filters are not in a position that would be even remotely possible to fill prior to install....neither my Honda or Harley could be filled even if you wanted to.
The Triumph Shop Manual is nothing more then a basic service guide. I am surprised there isnt a thread of "corrections" , missing and wrong information .
Old 05-10-2018, 09:38 AM
Main Motorcycle: 2008 Triumph Bonneville
Other Motorcycle: 1996 Harley Dyna
Extra Motorcycle: 1973 Triumph Tiger 750
Is this a big deal?
No, it's not, but don't make a habit of it.
Bob
bobscogin is offline
Old 05-10-2018, 10:10 AM
cadd's Avatar
I agree completely. I want to see someone fill this filter before spinning it on.
Riding it like I financed it.
cadd is offline
Old 05-10-2018, 12:36 PM
The Hornet's Avatar
Not every bike has the option to pre fill. My Thunderbirds sure don't as the filter mounts horizontal.
Don't worry about it, she'll fill very quickly once the engine is fired over.
Red Devil
The Hornet is online now
K&N Oil Filter Mishap- Oil Filler Cap Offensivemotor Air Cooled Twins Talk 72 06-24-2018 12:49 AM
Need Oil and Filter ADVICE PLEASE norton828 Air Cooled Twins Technical Talk 20 01-31-2018 09:19 PM
A few newb questions: Mr.Dudecool Classic, Vintage & Veteran 17 08-13-2015 02:34 AM
oil weeping from oil fill cap dilawn Street Triple Forum 13 06-24-2015 06:41 AM
multiple punch marks on crankshaft - this a problem? jonkster Classic, Vintage & Veteran 186 03-12-2015 08:00 PM
