Fork springs TEC - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 22 (permalink) Old 04-04-2018, 08:19 AM Thread Starter
Fork springs TEC
I am wanting to order the TEC fork springs for my thruxton. I've converted it to more of a scrambler so not sure what the difference in the thruxton and scrambler fork springs are. Would that be a good idea to put scrambler springs in the thruxton fork tubes?
Spdu4ia is offline
post #2 of 22 (permalink) Old 04-04-2018, 08:34 AM
Main Motorcycle: '07 Tiger1050
rode2rouen's Avatar
Other Motorcycle: "78 Kawasaki KZ750B
The differences would likely be spring rate and overall length.
The RaceTech web site should have spring rate info, and they'd be a good
source for info over the phone.
Rex
rode2rouen is offline
post #3 of 22 (permalink) Old 04-05-2018, 07:36 AM Thread Starter
So they are the same length just different spring rates? I was hoping for a simple no cut install and improvement in ride quality. I've never done any internal changes to a fork myself before.
Spdu4ia is offline
post #4 of 22 (permalink) Old 04-05-2018, 08:23 AM
rode2rouen's Avatar
What, exactly, is the issue you're trying to cure?
Rex
post #5 of 22 (permalink) Old 04-05-2018, 09:50 AM Thread Starter
Front end feel or "pogo sticking" from the stock springs. I already upgraded the rear just trying to balance it out.
Spdu4ia is offline
post #6 of 22 (permalink) Old 04-05-2018, 10:30 AM
rode2rouen's Avatar
Go here: http://racetech.com/index.aspx
You can compare the OEM spring rates of the Thruxton and Scrambler, and you can
check out the recommendations for your rig.
Rex
post #7 of 22 (permalink) Old 04-05-2018, 11:48 AM
Main Motorcycle: Triumph Bonneville T100
DesertBum's Avatar
Other Motorcycle: Prev. TigerXCX, Tiger abs
I'd also consider adding emulators if you get the springs. I put TEC springs in my '17 T100, then a few weeks later added the emulators (when they finally arrived,) and the emulators removed virtually all the pogo-sticking you're want to eliminate. They made more difference than the springs.
DesertBum is offline
post #8 of 22 (permalink) Old 04-05-2018, 01:12 PM Thread Starter
The preload adjusters?
Spdu4ia is offline
post #9 of 22 (permalink) Old 04-05-2018, 02:21 PM
6t
Main Motorcycle: The one that I am on
6t's Avatar
Other Motorcycle: 2002 Bonneville America
Extra Motorcycle: Honda RC30
I believe that the Scrambler fork tubes are longer than the Thruxton tubes, whether the springs are different lengths or whether the difference is made up with different spacers I have no idea.
FWIW I have Racetech springs with emulators, magic.
2002 T100 Anniversary. Lucifer Orange no more, "Scrambled"
Brakes and suspension, various Scrambler parts, speedo/tach in headlamp .
6t is offline
post #10 of 22 (permalink) Old 04-05-2018, 02:24 PM
6t
6t's Avatar
The preload adjusters adjust the spring tension for want of a better description. Emulators "emulate" valves in the fork tube to regulate the flow of oil , kinda like a damper sorta, I think...
6t is offline
How To: Progressive Suspension progressive springs cb200t Air Cooled Twins Technical Talk 3 03-04-2019 02:11 PM
Aussies: has anyone tried the Tec Bike Parts progressive fork springs? 3lliot Air Cooled Twins Talk 8 08-21-2018 02:20 AM
Hagon fork springs in '14 Speedy hglynrogers Air Cooled Cruisers - America, Speedmaster 1 08-25-2016 10:18 PM
Correct spacers for progressive fork springs? SkipII Air Cooled Twins Technical Talk 29 03-30-2015 01:08 AM
