Cam Backlash Gear Without Pin/Tools - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 16 (permalink) Old 08-20-2017, 06:48 AM Thread Starter
Main Motorcycle: Triumph Scrambler 2011
I've seen some great posts throughout here on the specs/process to DIY a set of locking pins/alignment tools for the cam backlash gear, which is all great stuff. It also appears that Triumph no longer manufacture/sell those tools, so this is seemingly the only route should I need to remove my cams (for instance, for sending overseas in a couple of weeks for a profile grind )
My issue is that I have very limited tools in my garage - the usual spanners, sockets etc - and that's about it, which will make it very difficult to jimmy up a set of these tools.
My question is - and I'm hesitant to ask (but will anyway) as I'm sure if it was that simple there would be reference to it already - can I simply get a few heavy duty cable ties and fix the backlash gear in place prior to removing (& simply snip them off when installed back in the bike)? I'm assuming being made of plastic they won't damage the gears, & I can swing off a couple of them fixed together so also assume they'd be strong enough to hold in place...
Can anyone highlight any issues I haven't thought about that would prevent this approach from being feasible?
Many Thanks
Wiley_AU is offline
post #2 of 16 (permalink) Old 08-20-2017, 07:15 AM
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: 2014 Ninja 1000ABS
You might be able to use ties, but I just bought a small machine screw with a nut and secured the gear through the hole. No need for Triumph's tooling. You can size the hole in the gears using a drill bit index if you have.
Baltobonneville likes this.
Felony is online now
post #3 of 16 (permalink) Old 08-20-2017, 12:04 PM
Legend
Main Motorcycle: 2008 Bonneville Black
Driftless Admin
BonnieBlack's Avatar
Other Motorcycle: Spousal 2009 Bonnie Black
I do what Felony does, which works great as long as you don't drop those little bits down into the motor. Whatever you do, make sure all holes are plugged/covered by shop rags before.
Not heard about anyone using cable ties. Not really sure they will fit through that hole. And the hole is bigger on one side than the other, so that angled head in Felony's picture is nice because it slides into the bigger side and keeps stuff from moving. But if it moves a bit it's not the end of the world, you can realign the gears if need be.
BonnieBlack is offline
post #4 of 16 (permalink) Old 08-20-2017, 04:58 PM
Main Motorcycle: 17 T120 Bonneville
N1ckel's Avatar
Other Motorcycle: 05 Bonneville cafe
+1 on the bolt, worked for me.
Sent from my iPhone using Tapatalk
05 790 Bonneville Black, AI gone, snorkel and baffle, Predators, 42/135, 1/4 turn, Thrux needles, 1 shim, Nology coil, Iridium plugs
17 T120 - Meerkat X Pipe
N1ckel is online now
post #5 of 16 (permalink) Old 08-20-2017, 05:27 PM
357Bob's Avatar
Spot weld them together. Then break the weld later. I had a friend that would spot weld his a/c clutch together on his old Dodge station wagon in the Spring and break the welds off in the fall. Worked for him. Might not be good on cam gears.
Sent from Motorcycle.com Free App
357Bob
357Bob is offline
post #6 of 16 (permalink) Old 08-20-2017, 07:02 PM
Main Motorcycle: 2010t100 67 ttspecial rep
mike-tt special's Avatar
Other Motorcycle: 91 zxr750(805cc)
you don't need the alignment pins for removing your cams if you are disassembling the backlash gears from your cams, i would recommend removing the backlash gears when you send your cams away to be re-ground.
while your cams are away you will have plenty of time to arrange for your nearest machine shop or friend with a lathe to make some for you out of some suitable mild steel rod or even a suitably sized bolt ready for when you get your cams back, it's worth spending a few quid/dollars to get them made as they'll be handy for any future valve shimming job . you have the dimensions from the thread you read to give to who ever makes them for you.
a little tip for when you get them, drill a hole through the butt end of each pin and lock-wire both of them together with a 4"- 6" length of thin lock-wire, this stops one dropping into the engine if it accidently becomes dislodged during use, and makes it harder to lose one while they are rattling around your tool box inbetween valve shimming jobs.
who wudda thought id wanna bonneville!
mike-tt special is offline
post #7 of 16 (permalink) Old 08-20-2017, 07:27 PM Thread Starter
Beauty, that's a great idea, cheers!
Wiley_AU is offline
post #8 of 16 (permalink) Old 08-20-2017, 07:29 PM Thread Starter
If I had the tools to do that I dare say I could DIY some backlash tools!
Wiley_AU is offline
post #9 of 16 (permalink) Old 08-21-2017, 08:14 AM
357Bob's Avatar
I used an old drill bit that fit the largest hole and ground one end down to fit the smaller hole size. But you need a grinder or a friend who has one. Mine aren't pretty but work great.
357Bob
357Bob is offline
post #10 of 16 (permalink) Old 08-21-2017, 09:18 AM Thread Starter
Cheers - I might knock on a few neighbour's doors, someone will have a grinder I'm sure!
Wiley_AU is offline
Cam drive gear help cjlima Air Cooled Twins Technical Talk 2 11-11-2016 06:16 PM
1982 T140 ES Cam tight after pinion (gear) installation 998cc Classic, Vintage & Veteran 4 06-09-2016 02:18 AM
Cam drive gear thrust washer MrTwin Air Cooled Twins Talk 3 04-26-2016 10:20 PM
