Cam Backlash Gear Without Pin/Tools - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #11 of 16 (permalink) Old 08-21-2017, 09:58 AM
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: 2014 Ninja 1000ABS
I have 6 in my basement. A bit far to travel I suppose.
Felony is online now
post #12 of 16 (permalink) Old 08-21-2017, 09:23 PM Thread Starter
Main Motorcycle: Triumph Scrambler 2011
Just a little! Would make for an interesting ride tho! :P
Wiley_AU is offline
post #13 of 16 (permalink) Old 06-05-2019, 03:54 AM
Main Motorcycle: 2005 Bonneville
I bought a 6mm aluminium rod, cut it to size, put it in a drill, drill in wise, then used a dremel tool to turn down to the correct diameter. Then I bent it as per the oem tool. Worked perfectly, no small parts to drop, and total cost of 3.
hassesbar is offline
post #14 of 16 (permalink) Old 06-05-2019, 04:47 PM
Main Motorcycle: 2011 Bonneville T100
BCThumper's Avatar
Other Motorcycle: 2010 Scrambler
Extra Motorcycle: 2009 DR650SE
I found a bolt that fit the big hole, then cut off the threaded portion and the head. Chucked the resulting rod in my drill press and used a file to reduce the diameter at one end to fit the small hole. Drilled a hole through the other end and attached a safety wire to prevent dropping it into the engine. Took only a few minutes to complete the whole project.
BCThumper is offline
post #15 of 16 (permalink) Old 06-05-2019, 06:38 PM
Main Motorcycle: 2014 Bonneville
Mike K.'s Avatar
Other Motorcycle: 2007 Ural Patrol
Extra Motorcycle: 2008 KLR 650
Zap straps won't hold everything in alignment. The anti-backlash spring is quite strong and will easily tear them. I tried it and wound up using a 1/8" steel pin punch to pry the two gearwheels into alignment while fitting the camshafts. It's tricky but can be done. I like the idea of a small screw or other piece of hardware to keep them aligned.
Mike K. is offline
post #16 of 16 (permalink) Old 06-05-2019, 07:13 PM
BCThumper's Avatar
I can vouch for the tension between the anti-backlash spring and the cam gear. The first time I had to change valve shims I used the screw and nut approach, but with one that was much too small. The spring pushed back and the screw was at about a 45 degree angle due to the pressure. I thought it would be a good idea to pry on the gear with a screwdriver to bring it back into alignment. This while holding the cam in my left hand. Of course, the screwdriver slipped, causing the screwdriver to spear my hand, passing all the way through and out the other side. I pulled the screwdriver out and tried to stop the bleeding with my cleanest dirty shop towel, noticed blood continuing to accumulate on the floor, and realized what happened. Fortunately, it missed the bones and major blood vessels. Just a reminder to be careful, especially if you aren't sure what you are doing.
Cam drive gear help cjlima Air Cooled Twins Technical Talk 2 11-11-2016 06:16 PM
1982 T140 ES Cam tight after pinion (gear) installation 998cc Classic, Vintage & Veteran 4 06-09-2016 02:18 AM
Cam drive gear thrust washer MrTwin Air Cooled Twins Talk 3 04-26-2016 10:20 PM
