need advice - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 16 (permalink) Old 12-30-2016, 07:39 PM
Main Motorcycle: '14 Bonneville T100
Location: Wilmington, NC - Winter, Downeast Maine - Summer
Other Motorcycle: '13 Street Triple
Extra Motorcycle: '07 Honda 919
If you're spraying carb cleaner into small holes and passages, watch your eyes!! You can easily have some of the spray come back into your face. Safety glasses or shield are mandatory. We'll not discuss how I know this!
Doberperson is offline
post #12 of 16 (permalink) Old 01-02-2017, 11:12 PM
Main Motorcycle: 2012 Bonneville SE
Other Motorcycle: 2015 BMW R1200RT
Originally Posted by Stinkycheezmonk View Post
I haven't tried this yet personally, but have seen it recommended by lots of others. I'm planning on trying it on my dirtbike over the winter: https://www.youtube.com/watch?v=zDkOgnPidPs
The PineSol Soak worked for me. I used it extensively on my carbureted Legend when I owned it. Soaked the metal parts for about 30 minutes. Do one carb at a time. I used compressed air to blow the jets clear of Pinesol before re-assembling the carbs. Get a new set of gaskets for each carb.
Jack
Birmingham, AL
Trophy4 is offline
post #13 of 16 (permalink) Old 01-04-2017, 05:57 PM
357Bob's Avatar
I've left motorcycle carbs soaking in CLR fur a day or two. Dissolves rust
Years ago a friend had a Jap car that would drain the carb bowl overnight. If you set and watched you could see a small drip coming out of small center Venturi. The gas was coming up a passage and dropping into the manifold. I looked and looked. I finally saw a very very small hole in the top area of the Venturi where it bent back down. Hard to explain but I managed to get it clean and that fixed it. Turns out I think that it was drilled there to break the syphon effect. It was too small to affect the mixture but it would allow air in and stop the syphoning when the engine was running. Very easily plugged up.
Point being is there are mysteries in these carbs and they have to be clean. Small passages we don't know about.
Sent from Motorcycle.com Free App
357Bob
357Bob is offline
post #14 of 16 (permalink) Old 01-04-2017, 11:25 PM Thread Starter
Main Motorcycle: triumph T100 2006
Other Motorcycle: triumph 650 bonnie 1972
Extra Motorcycle: custom 52 thunderbird
ITS ALIVE .so we can now close this thread thanks to all that contributed much love and respect guys . solution was to soak carbs then took to work blew out with compressor sprayed them again and ran fishing wire thru all holes to confirm they are clear . now purring like a content kitten time to go riding cheers all paul
triumphdownundr is offline
post #15 of 16 (permalink) Old 01-07-2017, 06:50 AM
Main Motorcycle: 04 T100 blue/white (his)
Wooly's Avatar
Other Motorcycle: 07 T100 red/black (hers)
Extra Motorcycle: 1971 Yamaha DT2 250
What did finally choose to soak them in?
Phil.
Wooly is offline
post #16 of 16 (permalink) Old 01-07-2017, 08:04 AM Thread Starter
soaked them in CRC heavy duty carbi cleaner
t509 headaches continue! any advice welcome.... sammy tweeks Speed Triple Forum 20 01-06-2017 01:09 AM
New to this Forum and need technical advice. galleje The Welcome Center 3 05-23-2016 11:24 AM
Advice on 2014 800 XC Wrkithot Tiger 800 - 800XC Mods & Workshop 14 01-14-2016 06:58 PM
Bonneville Newchurch vs the rest... advice? wesRBR Air Cooled Twins Talk 32 10-04-2015 02:09 PM
Scrambler Rims, Renew or Replace - Advice Sought GuzziChris Air Cooled Twins Talk 10 04-22-2015 01:36 AM
