MotorCycle Garage mat - Triumph Forum: Triumph Rat Motorcycle Forums
 4Likes
post #1 of 17 (permalink) Old 06-08-2016, 06:47 AM Thread Starter
Main Motorcycle: Bonneville T100 Black2012
Captain Bert's Avatar
Other Motorcycle: prev: BSA,Suzuki,Yamaha
Extra Motorcycle: I Wish
I want to use a garage mat under my Bonnie, which is good for any grime/oil etc dropped. But is there a product you can soak the mat in to prevent chrome rims etc from rusting eg. a rust inhibiter / oil that protects the bike from dampness. Plan to store the bike in my garage with a cycle cover over it. Any ideas???
2012 T100 Black : Predators, Ricor Intiminators, Ikon rear shocks, AI restricted, Air Baffle removed, Pretech 6 piston caliper, TTP Tune3
Captain Bert is offline
post #2 of 17 (permalink) Old 06-08-2016, 09:34 AM
Main Motorcycle: 2004 Thruxton 900
I don't think it works that way... maybe there's something you could coat the chrome in to protect it from pitting, I don't know. My advice would be to get a good dehumidifier for your garage, and to make sure that the cycle cover "breathes" rather than anything that's going trap moisture (the way a tarp would), otherwise the cover will only accelerate the rust.
dagus is offline
post #3 of 17 (permalink) Old 06-08-2016, 11:48 AM
+1, good post.
Plasma
plasma is offline
post #4 of 17 (permalink) Old 06-08-2016, 02:09 PM
Main Motorcycle: 2006 BONNEVILLE T100
RICHW's Avatar
Other Motorcycle: 1999 TITAN PHOENIX
RICHW is offline
post #5 of 17 (permalink) Old 06-08-2016, 04:27 PM
wbpolk's Avatar
I give my bike a WD-40 bath before storage.
Sent from my iPhone using Tapatalk
LAM likes this.
2009 Yamaha TW200
2010 Toyota Tundra
2005 Triumph Bonneville Black
wbpolk is offline
post #6 of 17 (permalink) Old 06-08-2016, 05:35 PM
Main Motorcycle: 2003 Triumph Speedmaster
Pig mats work well for oil. Can't help on the chrome.
https://www.newpig.com/pig-absorbent-mat-pad/p/MAT203
CzarSpeedMaster is offline
post #7 of 17 (permalink) Old 06-08-2016, 05:49 PM
Main Motorcycle: Thruxton
Other Motorcycle: Ducati 1000s & Paul Smart
This is what I do as well and have never had any problems.
tgleaton is offline
post #8 of 17 (permalink) Old 06-08-2016, 07:09 PM
Main Motorcycle: '09 T100 EFi
lambroving's Avatar
Other Motorcycle: Monster 796 ABS "Pantah"
Extra Motorcycle: K100RS 16/ABS
Just had a discussion about this with a pal. This is NOT the purpose of WD-40. He didn't believe me and had to research for himself.
WD-40:
“When it dries it leaves a varnish that attracts moisture in the air. That is what leads to rust. I have seen guns sprayed with WD-40 then stored away for a year or so that were one solid mass of rust, completely ruined. It does displace moisture until it dries out."
Had that happen to my Browning Medalist in the '60's stored inside its presentation case indoors!
Told him to use ACF-50 which he will now do.
'09 T-100 Forest Green / New England White, TORs, Intiminators & fork tubes raised 15mm, Chrome Ikon 7610 - SP8 Shocks, Custom Sargent Saddle, OEM Chrome Grab Rail, Conti Road Attack 2 EVO's 110/80VR19 & 150/70VR17, 7" Cibie lens and uprated H4 bulb.
lambroving is online now
post #9 of 17 (permalink) Old 06-08-2016, 08:14 PM
Main Motorcycle: 2012 T100
When I lived in the NE USA I had to store a bike and a sports car in the garage every winter.
Make sure as others have noted that you get a breathable, i.e. an INDOOR cover. Unless the garage floor is actually damp you really shouldn't have an issue with that much moisture from the floor and the breathable cover will not trap it because it isn't waterproof.
Breathe, Airbox Bafflectomy, O2/SAI off, TTP3, Predators, Chrome Stuff, Centerstand, Burton DS003, Ikons w/SP1 Spring, Maund Fins, Tec Monza Cap
paul e is offline
post #10 of 17 (permalink) Old 06-08-2016, 08:18 PM
RICHW's Avatar
http://www.motorex.com/index.cfm?oid...&eintragId=131
I've used this before and had good results.
RICHW is offline
Garage Flooring gbc Biker Hang-Out 29 05-28-2016 12:31 PM
20th Century Cycles aka Billy Joel's garage. nugpop Classic, Vintage & Veteran 4 03-30-2016 03:36 PM
Garage door remote KitNYC Maintenance & Workshop Talk 0 11-29-2015 12:38 AM
