Ive just replaced my t100 fork springs with hagon progressives. Recommended oil level is 150mm down from the top (with fork compressed and empty of internals) using 20 SAE oil (checked with hagon...these are their recommendations)
Has anyone used this recommended set up.......any thoughts on the resulting ride quality...changes made?
Just done exactly the same mod yesterday, plus i also fitted a pair of Hagon icon rear shocks at the same time.
The diffence was outstanding, it now handles like it's on rails, compared to the stock set-up, where the handling was more like riding on marbles.
I did exact same on my Scram a while back.
The Hagon springs came complete with a litre of 20W oil.
Set up by the book was fine and, in conjunction with fitting Ikons on the back, it transformed the ride.
I also took the opertunity of fitting pre-load adjusters which greatly aided the set-up.
Simple mod but very effective.............
Ventura,
In this link, ( http://www.triumphrat.net/1132937-post1.html ), you say, "20mm seems acceptable for your weight".
What is your weight? Some of us are in better paddocks than others
Did mine with Hagon springs last fall. The only further work I'll do on the forks is add a little more pre-load. It's a very smooth spring. For comparison I usually run racetech's but went for a change.
Related Threads
Triumph Rat Motorcycle Forums
3.9M posts
167.9K members
Since 2002
