Tachometer and Snatch America 2013 - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Cruisers - America, Speedmaster Cruiser chat for air-cooled bikes, America and Speedmasters
post #1 of 10 (permalink) Old 09-27-2019, 04:57 PM Thread Starter
Main Motorcycle: triumph bonnie america
Other Motorcycle: no
Extra Motorcycle: no
Wink Tachometer and Snatch America 2013
Hi everyone ,
i ride a 2013 america that suffers from snatch when bringing the power back in from low revs no matter how careful i am or what gear,I have read about exhaust change ,air filters air box removal and electronic gizmos but is this really necessary ? is there not a simpler solution?
Secondly does any one know where i can obtain a tachometer from a speedmaster efi 865 ( black face ) i understand i can install this to my america , there are plenty of examples on the internet that have, i contacted Triumph but they told me it would not fit and is no longer available,i am trying breakers but they seem to fly out the window pretty quick,the only ones available are outside the uk and very expensive.
Any ideas welcome.
regards
BelleAn3er1 is offline
post #2 of 10 (permalink) Old 09-27-2019, 06:33 PM
Main Motorcycle: '06 Tiger 955i
VABird's Avatar
Other Motorcycle: '12 T-Bird
Extra Motorcycle: '08 "AmeriMaster"
Try adjusting the throttle cables and then the throttle bodies.
I can't imagine why a Speedmaster tach won't fit an America.
The ride might be fun, but at the end, it really is the Destination that counts.
John 3:16
VABird is offline
post #3 of 10 (permalink) Old 09-27-2019, 07:02 PM
Main Motorcycle: 2015 Triumph America LT
Mrob's Avatar
try here: https://www.crosscountrypowersports.com
That's where I got one for my 2015 America. Give them a call, I found them to be very helpful.
Mrob is offline
post #4 of 10 (permalink) Old 10-01-2019, 08:19 PM
Main Motorcycle: 2002 Triumph America
Wire-Wheels's Avatar
Other Motorcycle: 1995 Triumph Sprint
Extra Motorcycle: 2000 Triumph Legend TT
Really, there is not much difference between an America and a Speedmaster. Just some minor bits. One of those is the tachometer. The Speedy has one. The America does not. The wiring for the tach is under the gauge cluster on the tank. Just buy one for a Speedmaster of the same year and plug it in. My America has an aftermarket tach that I bought (quite a bit cheaper) from DimeCityCycles.com ...J.D.
Wire-Wheels is offline
post #5 of 10 (permalink) Old 10-01-2019, 10:09 PM
VABird's Avatar
I think the tach was a factory option / accessory for the America.
I've had 3 Americas, two of which had one.
I think you just need a carb or efi tach, not necessarily the same year.
John 3:16
VABird is offline
post #6 of 10 (permalink) Old 10-02-2019, 06:14 AM
True about the carb or EFI thing. That, and white or black faced dial was the
difference. Dealers had the accessory tach in stock at one time, but they were awfully expensive (like all the factory accessories). ...J.D.
post #7 of 10 (permalink) Old 10-02-2019, 12:22 PM
Main Motorcycle: 2012 Triumph America
rbastedo's Avatar
Other Motorcycle: 1980 Yamaha Virago
I also got mine at:
There is a thread on here maybe in the "air cooled technical talk" forum.
I know I posted in it, as did others and there will be specific part numbers there.
Easy install, and it's a "nice to have" item but yeah is pretty expensive.
rbastedo is offline
post #8 of 10 (permalink) Old 10-02-2019, 12:53 PM
rbastedo's Avatar
rbastedo is offline
post #9 of 10 (permalink) Old 10-14-2019, 09:43 PM
Main Motorcycle: 2013 Triumph America
Other Motorcycle: None
Extra Motorcycle: 2017 Dodge Challenger SRT
When I bought my 2013 new, and had the dealer add a tach, he told me straight up it was a Speedy tach, so they fit and work. My only problem is the case seal is not tight and a little condensation has fogged the glass. I need to look into taking it apart and permanently sealing it from outside humidity, which is as bad or worse than in the UK.
As far as the "snatch" - with help from the Forum (Matty) I removed the air injection system using the kit (available from your local aftermarket sites), removed the exhaust gas O2 sensors (also using a kit) and installed a TuneECU program that disabled the O2 sensor system, and the angels sang over my bike. The previous off idle stall that embarrassed me at many a stop light has been gone ever since.
Jupiter Bob
rwm33418 is offline
post #10 of 10 (permalink) Old 10-20-2019, 03:17 PM
The TuneECU map that I installed is 20516. Like I said, it works great.
Jupiter Bob
rwm33418 is offline
