battery monitor - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Cruisers - America, Speedmaster Cruiser chat for air-cooled bikes, America and Speedmasters
 1Likes
  • 1 Post By VABird
post #1 of 7 (permalink) Old 08-19-2019, 01:21 PM Thread Starter
battery monitor
Hi Guys i'd like to put a battery condition display so i can keep my eye on what voltage is in the battery ,has anyone done this and any useful links (2009 triumph america )
Cheers Steve
nightfire10 is online now
post #2 of 7 (permalink) Old 08-19-2019, 06:10 PM
Main Motorcycle: '06 Tiger 955i
VABird's Avatar
Other Motorcycle: '12 T-Bird
Extra Motorcycle: '08 "AmeriMaster"
If you mean a voltage gauge, I just did this on a 2008 America in a thread here:
https://www.triumphrat.net/air-coole...fo-lights.html
Your challenge would be to find a location for the gauge, but it is a fairly easy modification.
Be sure to power it from a switched fuse, not from headlight, etc., or you'll show a false low. There is voltage drop between the battery and lights.
nightfire10 likes this.
The ride might be fun, but at the end, it really is the Destination that counts.
John 3:16
VABird is offline
post #3 of 7 (permalink) Old 08-19-2019, 09:49 PM
Main Motorcycle: 2009 America EFI
MattyMo's Avatar
Hey Steve, sorry, I don't have any help with a battery health indicator.
Can't help but wonder if wanting to know the battery state/charge voltage might lead to a new aftermarket rectifier/regulator
I know my OEM rec/reg's charge characteristics didn't leave me with much confidence when chasing low battery issues years ago.
2009 America with some modifications, a lot of fun that I can ride all day. (sold and miss my 2008 Bonneville, a great daily driver)
this message was created using recycled electrons
MattyMo is offline
post #4 of 7 (permalink) Old 08-20-2019, 04:08 AM Thread Starter
Might be my problem as I don't use it a lot it losses charge
Sent from my SM-G930F using Tapatalk
post #5 of 7 (permalink) Old 08-20-2019, 05:45 AM
VABird's Avatar
...so why not keep it on a battery tender?
John 3:16
VABird is offline
post #6 of 7 (permalink) Old 08-20-2019, 07:41 AM Thread Starter
1st floor flat ! No power in car park
post #7 of 7 (permalink) Old 08-20-2019, 08:45 AM
MattyMo's Avatar
I tend to ride to work and errands more than long weekend excursions. The low voltage situation from lots of cranks with too few miles ridden to regenerate that charge left me just below that magical battery voltage threshold of the ECU on more than one occasion.
Two things I did that really helped were adding a Powerlet outlet and upgrading the rec/reg.
The Powerlet outlet (and DIY adapter with wires terminated into clips) was great for easier access to the battery. That allowed verification of battery voltage and ability to connect to an external power source so the ECU sensed enough voltage to allow the starter motor to engage. And of course it also provided an easier path to charge the battery without having to remove multiple parts using three different tools. *I did also change all those fasteners leading to the battery with SS Phillips screws so only one common tool was needed!
An aftermarket MOSFET rec/reg (Rick's Hot Shot) helped to provide a much more stable and a bit higher charge voltage to the battery.
I think changing to an LED headlamp also helped the battery situation when the key is first turned on. The LED drawing a fair bit less voltage than the OEM incandescent lamp from the battery when the ECU is sensing that voltage and determining if it will allow the starter to engage.
Like the OP I do not have a garage. I do park under a car cover and can run an extension cord for a needed charge but not practical for regular or daily "Battery Tender" use.
MattyMo is offline
