Trailing Brake - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Cruisers - America, Speedmaster Cruiser chat for air-cooled bikes, America and Speedmasters
 3Likes
  • 1 Post By 290GTP
  • 1 Post By MattyMo
  • 1 Post By d100allenbaugh
post #1 of 10 (permalink) Old 05-11-2019, 12:04 AM Thread Starter
Newbie
Main Motorcycle: Triumph America. 2013
Trailing Brake
Hi Guys, I have 2013 Triumph America and I was out there practicing figure of 8 turns and slalom turns in an empty parking lot today for about 20 minutes. I was using trail braking the entire time and all of a sudden my rear brake went dead. I stepped on the foot brake on the right and had no response. I stopped my motorcycle, checked on the foot brake pedal and it was dead. But after a minute or two, it came back. Have any of you experienced something like this?
SpringLight is offline
post #2 of 10 (permalink) Old 05-11-2019, 01:21 AM
290GTP's Avatar
Brake fade. Probably boiled the fluid from heat.
SpringLight likes this.
290GTP is offline
post #3 of 10 (permalink) Old 05-11-2019, 06:00 PM
Main Motorcycle: 2009 America EFI
MattyMo's Avatar
I agree it would be heat related from overuse. @SpringLight have you checked the rear brake fluid level since? Hopefully it is still near the typical level. How many miles on the odometer? If you have a scheduled service coming up in the not so distant future you may want to make sure the brake fluid is renewed.
2009 America with some modifications, a lot of fun that I can ride all day. (sold and miss my 2008 Bonneville, a great daily driver)
this message was created using recycled electrons
MattyMo is offline
post #4 of 10 (permalink) Old 05-12-2019, 02:22 PM
Main Motorcycle: 08 t100
Other Motorcycle: 08 Thruxton
Extra Motorcycle: 72 Norton comando
As far as I know trail braking on a motor cycle means using a slight pressure on the front brake through the first half of a turn, which I often practice. Using the rear brake in a turn is probably not a good idea IMO.
rweb is online now
post #5 of 10 (permalink) Old 05-12-2019, 06:44 PM
MattyMo's Avatar
I have always felt trail braking is more about dragging the rear brake. This then settles the front down for the upcoming maneuver.
Was guessing the OP was working on riding skills and just over did it.
MattyMo is offline
post #6 of 10 (permalink) Old 05-12-2019, 07:12 PM
290GTP's Avatar
Technically you are right regarding using the front brake on high speed turns. Using the rear to trail brake when cornering at high speeds can be fraught with danger. Unless your on the dirt.
I always trail the rear brake for low speed maneuvers, settles the bike down nicely.
290GTP is offline
post #7 of 10 (permalink) Old 05-19-2019, 04:56 PM
Main Motorcycle: 2002 Triumph America
Wire-Wheels's Avatar
Other Motorcycle: 1995 Triumph Sprint
Extra Motorcycle: 2000 Triumph Legend TT
When I hear the expression "trail braking" I take it to mean anytime you apply braking (front or rear) after you have already committed yourself in a turn. It can be to adjust speed a little. It can be to shift the weight of the bike more to the front wheel. If you are good enough, it can even be used to rotate the bike (front brake) a bit in the turn (usually along with a bit of countersteer). That has always been my understanding of "trail braking".
... J.D.
Wire-Wheels is offline
post #8 of 10 (permalink) Old 06-11-2019, 09:50 PM
Main Motorcycle: 2018 Triumph Speedmaster
I've been practicing trail braking for the last several weeks and it is great. More control for curves. The way I was taught is you use your front brakes AND possible your throttle. I was taught to put your left 2 fingers on your front break and the two right fingers and thumb on the throttle. Lay off the throttle going into the curve and "gently" use the front break into the curve and then throttle up as you go past the apex of the curve. Have both control of the front break and throttle at the same time is really easy and comfortable once you get the hang of it. I have SOOOO much less stress going into curves especially curves I am not familiar with.
Try it, you'll like it.... Dave
LadyBonnie likes this.
d100allenbaugh is offline
post #9 of 10 (permalink) Old 06-12-2019, 05:58 AM
Yup ! That is one of those things that feels so good when you get it right. Along with some counter steer or standing the bike up a bit if you need to move your line over a bit in mid-corner are techniques that give you confidence out there. Skills you learn over time. ...J.D.
post #10 of 10 (permalink) Old 06-12-2019, 08:20 PM
Main Motorcycle: Bonneville Speedmaster
LadyBonnie's Avatar
I understand that this condition is common and can be caused by excessive use of rear disc brake. Even some of the motorcycles at the MSF course were getting slushy rear brakes after a day of fiction zoning the parking lot. I also remember driving a small car down a steep long mountainous highway and having almost no brakes by the time I reached at the bottom of the mountain. This all in the lowest gear too. So it happens on motorcycles disc brakes as well.
I guess the key is to use both brakes with different degrees of pressure, depending on the situation. After watching the cayonchaser.net video on Trail-braking, I learned that trail-braking is lightly using the front brake coming into a corner and then slowly trailing off the front brake just before reaching the apex of the corner and then slowly increase throttle as the bike is now pointing in the right direction , completing the corner. If done properly it can be a lifesaver as you now have more control in a corner and can even come to a controlled stop in the middle of a blind corner if needed. But like anything, it takes practice. Just my opinion. Ride safe
LadyBonnie is offline
Altrider Brake Pedal Enlarger fredrider Tiger 1200 - Mods & Workshop 6 08-16-2019 05:54 PM
Rear brake problems. 1977 T140V MLW9110 Classic, Vintage & Veteran 10 06-20-2018 03:55 PM
Rear brake mystery issue ThingsWeNeverDi Air Cooled Twins Technical Talk 6 08-15-2016 08:02 PM
issue with aftermarket brake lever and brake light not lighting when squeezed horse86 Speed Triple Forum 23 03-27-2016 01:40 AM
Front brake wheel, what is it for? Torro Daytona Deliberations 7 10-10-2005 05:47 PM
