front sprocket locking tab / washer - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Cruisers - America, Speedmaster Cruiser chat for air-cooled bikes, America and Speedmasters
 2Likes
post #1 of 13 (permalink) Old 09-13-2017, 12:50 PM Thread Starter
Main Motorcycle: 2007 Bonneville America
Other Motorcycle: 2010 Thunderbird SE 1600
Extra Motorcycle: Jeep Grand Cherokee
Just about ready to put new chain / sprockets on the America and need to buy new front sprocket locking tab / washer.
Figure I should probably not re-use it yet again!!
Would appreciate input as to where to buy this part.
Thanks
ChrisonTop is offline
post #2 of 13 (permalink) Old 09-13-2017, 12:57 PM
Main Motorcycle: 2015 Triumph Speedmaster
mhoward's Avatar
Other Motorcycle: Wife's 2010 Speedmaster
Wild guess, but maybe a dealer?
Just getting started with motorcycle adventures
mhoward is offline
post #3 of 13 (permalink) Old 09-13-2017, 07:46 PM
Main Motorcycle: 2009 America EFI
MattyMo's Avatar
Local dealer if you have one. Bike Bandit or Hermy's Triumph store. Hermy's would likely be faster than the Bandit.
2009 America with some modifications, a lot of fun that I can ride all day. (sold and miss my 2008 Bonneville, a great daily driver)
this message was created using recycled electrons
MattyMo is offline
post #4 of 13 (permalink) Old 09-14-2017, 06:26 AM Thread Starter
Thanks for the obvious, Howard! Next time save your input.
I would not be asking if I had not already tried that route!
In fact it seems the only Triumph dealers around Boston have switched to other (Jap) brands.
I did end up ordering one but even that dealer (in Georgia) did not have one on hand.
Seems like Triumph could do a much better job with after sales parts and service.
Will bookmark Hermy's - thanks Matty
post #5 of 13 (permalink) Old 09-14-2017, 07:42 AM
The Hornet's Avatar
Unless the washer has been destroyed it's reusable. I've reused the one on my 2003 several times.
Just take a screwdriver or small chisel and tap it flat enough to remove the nut.
Back2-2 likes this.
Red Devil
The Hornet is offline
post #6 of 13 (permalink) Old 09-14-2017, 08:13 AM
Legend
Main Motorcycle: 2008 Bonneville Black
Driftless Admin
BonnieBlack's Avatar
Other Motorcycle: Spousal 2009 Bonnie Black
I've reused mine many times as well. You do not need to routinely replace it.
Back2-2 likes this.
BonnieBlack is offline
post #7 of 13 (permalink) Old 09-14-2017, 08:37 AM
Main Motorcycle: '02 Bonneville 100yr anv.
Back2-2's Avatar
Other Motorcycle: 2006 Honda 450X
If you are concern you have used it too many times -flatten it and use two of the other areas to bend back against the nut. Good to go.
“Its all about motorbikes. Always has been, always will be”
Neil in the Black Hills
Back2-2 is online now
post #8 of 13 (permalink) Old 09-14-2017, 02:45 PM
Main Motorcycle: 2006 Bonneville T100
LT-100's Avatar
Other Motorcycle: 2014 Triumph America LT
I just replaced my chain and sprockets on my 2006 T100, with a genuine Triumph chain and sprocket set. The set came with the lockwasher. Obviously, that won't help if you go with aftermarket chain and sprockets!
LT-100 is offline
post #9 of 13 (permalink) Old 09-15-2017, 05:27 AM Thread Starter
Thanks for all the serious answers. I've got one on order now, though it's hard to believe that little piece of steel is really worth about $6!! Thanks, guys.
post #10 of 13 (permalink) Old 09-15-2017, 11:39 AM
mhoward's Avatar
Well, you didn't mention the fact that you tried a dealer or tried searching online, so how is anyone supposed to know? Glad you found a place to order one though. It's too bad the dealers around you don't carry them, you'd think it's something they'd have a few on hand for. But then again, it's probably not something that flies out the door every day. Have a good one!
mhoward is offline
17T front sprocket on a 07' Speedmaster... what do you think? doctaton Air Cooled Twins Technical Talk 9 07-17-2017 05:55 PM
Rebuild Master Cyllinder... nickolender Hinckley Classic Triples 4 07-03-2017 10:59 PM
Changing the front sprocket. wisteria Air Cooled Twins Technical Talk 40 01-29-2016 02:00 PM
Longer chain for increase in front sprocket size? agentjay49 Air Cooled Twins Technical Talk 4 04-23-2015 12:22 PM
Street Triple R front brake locking professorseth Street Triple Forum 4 04-20-2015 05:59 PM
