Centre Stand for America - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Cruisers - America, Speedmaster Cruiser chat for air-cooled bikes, America and Speedmasters
 4Likes
post #21 of 31 (permalink) Old 06-01-2017, 10:55 PM
Main Motorcycle: 2007 America
enroute1's Avatar
Other Motorcycle: 2014 Honda Valkyrie
Extra Motorcycle: 1982 Honda CB900 Custom
Originally Posted by Americaoak View Post
The Norman Hyde Center stand came yesterday evening. I will install this week-end. I do not have a tech new phone but it does have a camera so will take a photo or two while I do it.
Product looks well made and the install looks straight forward......we'll see.
Oak
Would like to know if there are any drag issues while cornering....
enroute1 is offline
post #22 of 31 (permalink) Old 06-02-2017, 03:29 PM
Main Motorcycle: 2014 Street Triple R
Originally Posted by Wakinyan View Post
I use a $20 wheel roller setup from Harbor Freight and a 2x4 under the side stand to make it more vertical for cleaning wheel & lubing chain.
I do the same. Isn't perfect but better than rolling it back and forth.
15Speed is offline
post #23 of 31 (permalink) Old 06-02-2017, 03:45 PM
Main Motorcycle: Triumph America
Americaoak's Avatar
Other Motorcycle: '94 jeep wrangler
OK, I installed last night. Sorry but was excited to do it and did not take any pictures.
Install was easy and quick though. Took a total of maybe an hour and a half.
Had to remove the mufflers (stock in my case) to gain access. One note, on my 2012 America there is a bracket holding some anti pollution stuff right where you need to work. The bracket is bigger than it needs to be and impedes the center stand from mounting. All that is required is removing the bracket and sawing off the excess. Took maybe an extra three minutes.
Now the guys were sooooo right. Getting this cruiser up onto the center stand is bitchin' All the weight is forward.
However the trick mentioned earlier about using a 2x4 worked GREAT.
And I cut the 2x4 to a length I can wedge under the frame so that I can get the front wheel off of the ground too. So I can work on it too after it is up on the stand.
It was great to be able to easily clean the rear wheel chain side and work on the chain in a much more satisfactory way than I ever was able to do before.
This weekend I will go for a long mountain ride with lots of twisties so will report back on any reduction of lean angle I might encounter.
Till monday then.....
Oak
Americaoak is offline
post #24 of 31 (permalink) Old 06-05-2017, 01:44 PM
Americaoak's Avatar
So this week-end I rode HYW 145 in Colorado from Norwood to Telluride then HWY 50 to Montrose and back. About 150 miles. This highway is famous for its scenery and twist as it follows the San Miguel river and Leopard Creek and then crosses Dallas Divide (11,000 +) pass. To say the least this road is curvacious.
Now it should be stated that I am not an aggressive rider by and large. I will sometimes drag a floor board but not often and there is a reason I ride the America instead of a Bonney as I like to ride more laid back.
However for this discussion I rode about as aggressive as I am able to and never once did the center stand impede my lean angle.
Once back to the ranch it was great to be able to set up onto the center stand and EASILY and much more thoroughly oil the chain than I ever was able to do on the roller stand I have.
There is an adjustment on the center stand so that when it is up it does not touch the muffler. I found however that it tucked up to the muffler rather firmly and was best that way. Adjusting it so that it didn't touch the muffler allowed it "chatter" as the spring is then in less that optimum position to hold the stand tight. It would also hang a bit lower than the way I have it.
OK, there you have it a full report on the Hyde center stand for the America. (2012)
Oak
Oak
post #25 of 31 (permalink) Old 06-06-2017, 01:34 AM
enroute1's Avatar
Thanks.....Sounds GOOD!
enroute1 is offline
post #26 of 31 (permalink) Old 06-06-2017, 10:26 AM
Oak
Gah I miss CO so much.
brgsprint likes this.
15Speed is offline
post #27 of 31 (permalink) Old 10-23-2018, 11:08 AM
Newbie
pg44's Avatar
When the bike is raised on the centre stand, can you access and unscrew the oil filter easily?
Also, is it possible to remove the rear wheel and swing arm?
I'm planning to install a belt drive conversion kit and need to know if I can do that with the centre stand alone, i.e. without a motorcycle jack.
Cheers
pg44
Triumph America 2013
pg44 is offline
post #28 of 31 (permalink) Old 10-24-2018, 10:04 AM
Main Motorcycle: 2009 Speedmaster
1arryb's Avatar
I'm still using a DIY wood block lift I built for my previous bike. It's adequate for chain maintenance but isn't really high enough to remove the rear wheel. If I was more serious about home maintenance, I'd get a real lift. For the road, there's AAA.
1arryb is online now
post #29 of 31 (permalink) Old 10-24-2018, 10:37 AM
Main Motorcycle: 2009 America EFI
MattyMo's Avatar
Cheers
Yes. Although something like this works great for me compared to the cost and challenge of getting the motorcycle up on the center stand.
https://www.motea.com/en/constands-x...ic-lift-322145
No. At least not without removing the rear fender at the least.
If you do the belt conversion please post a thread of the activity and your after conversion experience.
2009 America with some modifications, a lot of fun that I can ride all day. (sold and miss my 2008 Bonneville, a great daily driver)
this message was created using recycled electrons
MattyMo is offline
post #30 of 31 (permalink) Old 10-24-2018, 08:16 PM
Main Motorcycle: 2015 Triumph America LT
Mrob's Avatar
Yes I'd like to hear/see the belt conversion. I've read in threads on here prior that it can be pricey. Have been wondering if it still is.
Mrob is offline
Best service centre in Melbourne?? au borris40 Thunderbird Cruiser Chat 0 04-02-2015 06:00 PM
Centre stands Gazbo Hinckley Classic Triples 19 03-02-2015 09:11 AM
