Triumph Forum: Triumph Rat Motorcycle Forums - View Single Post - Stuck throttle
Thread: Stuck throttle
View Single Post
post #2 of (permalink) Old 10-31-2011, 09:31 AM
davetac1
First: If the weather is cold where you live,it's possible that somethin in the throttle system may have iced up.
Second:Are your throttle cables adjusted correctly??? If they're not,that could cause the throttle to stick.There's a section in the OM explaining the throttle adjustment procedure.
Third:Has anyone worked on your machine recently??If so,it's possible that somethin didn't get put back together right.
And fourth: A component in the system may be goin bad.
At any rate,ya wanna get it checked and fixed ASAP,as a sticking throttle can get ya into some real serious trouble, real quick.
Anyways, there's a couple things to look at. Good luck. Dave!!!
davetac1 is offline
