Triumph Forum: Triumph Rat Motorcycle Forums - View Single Post - Driving Light/Fog Light Kit
View Single Post
post #2 of (permalink) Old 06-18-2011, 11:03 PM
BullClark
Light kit
I bought the light kit before I discovered that Triumph instructions said to remove the forks to install the kit.
I thought a lot about what you are considering doing to save some money. The stock light bracket is fairly thick and would take some time and patience . I finally chickened out and let my dealer do it, cost $ 200.00 to remove old brackets and install the new kit. Was it worth it, to me yes because a small slip with the grinder / cutter and you have spent a lot more money buying fork tubes,oil and what ever.
Be careful and do it the way you are most comfortable with.
BullClark is offline
