Engine cover bolt torque - Triumph Forum: Triumph Rat Motorcycle Forums
 3Likes
post #1 of 22 (permalink) Old 06-16-2017, 05:40 PM Thread Starter
Main Motorcycle: '16 Thruxton 1200
Getting ready to put some black engine covers on my Thruxton and I can't find the bolt torque values anywhere. Anyone know these by chance?
TRSCobra is offline
post #2 of 22 (permalink) Old 06-16-2017, 06:25 PM
Main Motorcycle: 2016 Triumph Thruxton R
SirCuffsalot's Avatar
@TRSCobra
Here you go... This is the link to the Triumph Black Engine Cover Fixing/Bolt Kit (A9618190).
It has the Triumph recommended torque values for each bolt, and even states what the best order to torque each one is. Just click the link below! Cheers.
(It states each bolt for both engine covers has a torque value of 10Nm and/or 7.4ft-lbs.
And if you bought the Triumph Black Sprocket Cover as well, the torque value for those four bolts are 9Nm/6.6ft-lbs.)
http://www.triumphinstructions.com/P...9618190-US.pdf
TRSCobra likes this.
Dukes of Hazzard Big-Wheel -> Redline PL-20 -> SE PK Ripper -> Ninja ZX-6R -> CBR F4i -> R6 Raven -> Monster S2R Dark -> Daytona 675 -> Speed Triple -> Thruxton R
Last edited by SirCuffsalot; 06-16-2017 at 07:12 PM. Reason: Corrected the link for you.
SirCuffsalot is offline
post #3 of 22 (permalink) Old 06-17-2017, 12:04 PM Thread Starter
Originally Posted by SirCuffsalot View Post
@TRSCobra
Awesome! That's exactly what I need!
Thanks so much :cheers:
TRSCobra is offline
post #4 of 22 (permalink) Old 06-19-2017, 04:53 AM
Main Motorcycle: Street Twin
Other Motorcycle: Kymco 300i
If you have a torque wrench capable of telling the difference between 9 and 10 N.m you must work for NASA! Even getting one that reads (accurately)that low is hard.
STroadster is online now
post #5 of 22 (permalink) Old 06-19-2017, 06:03 AM
I bought a Craftsman Micro torque wrench at Sears. It reads accurately from 5ft-lbs to 75ft-lbs. So far so good with it. (6Nm to 101Nm)
post #6 of 22 (permalink) Old 06-19-2017, 03:06 PM Thread Starter
Got it all apart but the hex head stator bolts and torx head magnetic pickup screws weren't included with the kit, and I cant find the tq specs on those. Sounding like I should've had the dealer do this...
TRSCobra is offline
post #7 of 22 (permalink) Old 06-19-2017, 03:19 PM
Forchetto's Avatar
The 3 bolts that hold the stator to the cover 12 Nm
The 2 that hold the crankshaft position sensor to the cover 9 Nm
Forchetto is offline
post #8 of 22 (permalink) Old 06-19-2017, 05:39 PM Thread Starter
Thank you!
Are there any on the clutch side I need to worry about before opening that side up?
TRSCobra is offline
post #9 of 22 (permalink) Old 06-19-2017, 07:21 PM Thread Starter
I think my smallest TQ wrench will work fine. Bought a brand new set for when I started modifying my LS7. They're not cheap to fix!
I don't work for NASA, but this 1200cc bike feels like a rocket ship to me!
TRSCobra is offline
post #10 of 22 (permalink) Old 06-19-2017, 08:11 PM
Main Motorcycle: 2005 Speed Triple 1050
Mike.Gayner's Avatar
How do you know it reads accurately? I agree with STroadster, I don't trust any consumer grade torque wrench to read accurately at low torque settings, and certainly wouldn't rely on a torque wrench at values under, say, 15 or 20 ft-lb.
Mike.Gayner is offline
Black Engine Cover Kit No Longer Available? TRSCobra Water Cooled Twins Talk 7 04-27-2017 09:50 AM
Missing plug on engine cover Pn2501 Water Cooled Twins Technical Talk 16 04-24-2017 08:45 PM
Engine Cover Removal and Replacement ThruxtonNewbie Air Cooled Twins Technical Talk 11 01-12-2017 11:40 AM
Replacing Engine Mount Bolt? fjrkeith Speed Triple Forum 3 09-08-2016 01:15 AM
handle bar bolt torque sonny58 The Rocket Science Forum 2 08-25-2015 02:21 AM
