T120 Speedo-Odometer error? - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
  • 1 Post By FourtyFourty99
post #1 of 6 (permalink) Old 06-19-2017, 03:18 PM Thread Starter
Main Motorcycle: 2016 T120 Bonneville
Soulkicker's Avatar
Other Motorcycle: 1977 KZ1000A
2016 T120
Has anyone checked there speedo and OD against other vehicles or devices?
I've been messing with it over the weekend against my son's 2016 Ford and my very accurate GPS.
I am a bit disappointed to find that at an indicated 40mph my true speed is 37mph and at 90mph my true speed is 84mph.
That is as bad as my 40 year old Kawasaki mechanical speedo/OD, which works with an archaic, cable shaft drive, spinning magnet in a cone connected to a needle!
I guess that would be about +6% error across the 0-100mph range.
If my OD displays are off this much too, this now substantially changes what I though my killer fuel 65mpg-72mpg economy has been.... dang it.
Anyone else?
Are the electronics calibrateable?
Soulkicker is offline
post #2 of 6 (permalink) Old 06-19-2017, 03:36 PM
Main Motorcycle: '17 Bonneville T120 Black
FourtyFourty99's Avatar
I've never come across a motorcycle with an accurate speedometer. Even most vehicles are off by a few miles. I can't recall if the speedometer is installed in the front hub or part of the transmission. It's typically left to have some margin of error in case the owner switches tire profiles.
saddlebag likes this.
FourtyFourty99 is offline
post #3 of 6 (permalink) Old 06-22-2017, 09:42 AM
Main Motorcycle: Triumph T120 2017
circuit_78's Avatar
Other Motorcycle: ...
Extra Motorcycle: Nil
so far among all the bikes I have... only digit ones from the sports bike etc are bang on... the rest as long as a needle involve , is always reading higher than actual.
well trick u ride slower ahahhaha
2015 t.scrambler _ 2009 yamaha r1 _ 2008 honda xr400 _ 2007 suzuki rm250 _ 2006 honda super4 _ 1996 ktm125
circuit_78 is online now
post #4 of 6 (permalink) Old 06-22-2017, 01:31 PM
Dougl1000's Avatar
Reading 6% high is almost exactly what they did with the Rocket. It's a built in incentive not to break the speed limit.
Dougl1000 is offline
post #5 of 6 (permalink) Old 06-22-2017, 01:38 PM
Main Motorcycle: 2010 Bonneville base
Seadog49's Avatar
Other Motorcycle: '64 Honda CB77 Superhawk
Mine's even worse than 6%. Speedo reads 45 and I'm actually at 38.
Seadog49 is online now
post #6 of 6 (permalink) Old 06-22-2017, 01:44 PM
Main Motorcycle: '09 T100 EFi
lambroving's Avatar
Other Motorcycle: Monster 796 ABS "Pantah"
Extra Motorcycle: K100RS 16/ABS
Originally Posted by Soulkicker View Post
2016 T120
Not sure where YOU'VE been...
ALL motorcycle speedos read optimistically. It's apparently a legal requirement in many countries. Your odometer should be bang-on however..., provided you have air in your tires...
FWIW, Ducati's with ABS read exactly +10% but mileage is dead accurate.
'09 T-100 Forest Green / New England White, TORs, Intiminators & fork tubes raised 15mm, Chrome Ikon 7610 - SP8 Shocks, Custom Sargent Saddle, OEM Chrome Grab Rail, Conti Road Attack 2 EVO's 110/80VR19 & 150/70VR17, 7" Cibie lens and uprated H4 bulb.
lambroving is offline
Speedo drive rubbing on hub - what's wrong? mmanasas Classic, Vintage & Veteran 2 05-26-2017 02:21 PM
2016 Triumph T120 Vs. Indian Scout u6crash Biker Hang-Out 44 04-01-2017 12:05 PM
T120, first gear ratios, error? Soulkicker Water Cooled Twins Technical Talk 7 02-21-2017 08:08 PM
Speedo, 6mph out on t120 oskar866 Classic, Vintage & Veteran 27 12-08-2016 04:37 AM
Triumph T120 alternative adamtal Water Cooled Twins Talk 43 10-24-2016 08:56 PM
