T120 Handle Bar Risers - Triumph Forum: Triumph Rat Motorcycle Forums
 4Likes
post #1 of 24 (permalink) Old 05-13-2017, 06:00 PM Thread Starter
Main Motorcycle: T100
Been scanning the web but can't find any risers for my 17 T120. Would like to raise them just a little so I don't have to replace cables. Any one know of any? Thanks
alank43 is offline
post #2 of 24 (permalink) Old 05-14-2017, 02:46 AM
Main Motorcycle: T120 Blk / Graphite
beagle1's Avatar
Other Motorcycle: collapsible pushbike
Extra Motorcycle: taxi
I ended up getting 35mm washers around 2.5mm thick and placing them between the existing mounts and rubber inserts. Initially put 4 in and ended up dropping back to two. Also under the edge of the base of the riser put two smaller washers to take up the gap. With this set up I could use the OE bolts, with 4 washers had to use 75mm bolts. M10 1.25 thread at 75mm long. I found with 4 spacers plus the two x1mm spacers under the riser cap, (total 12mm.. Near 1/2") the handling felt heavy in the front end, probably my brain, but with two washers, around 7mm rise total, it just took the edge off leaning forward and handled good. Total cost was under $5 with using 4 spacers with new bolts, $1 only using two spacers..It doesn't take much rise to improve the comfort. No problem with hoses etc.
erey and mamsbaugh like this.
old bikers never die....they just smell that way
beagle1 is offline
post #3 of 24 (permalink) Old 05-14-2017, 05:21 AM
Main Motorcycle: 2017 T120 B Matt Graphite
Lioneagleman's Avatar
Any chance you can put a photo up? This may be my next modification!
Sent from my iPad using Tapatalk
Lioneagleman is offline
post #4 of 24 (permalink) Old 05-14-2017, 10:38 AM
Main Motorcycle: all of them
Other Motorcycle: Thruxton Tiger 800,
Extra Motorcycle: T140, BSA B50, BSA A65,
Talk about horses for courses. I spent a week on a rental T120 and felt the handlebars are too tall.
But I was cruising at 80 mph+ through southwestern deserts
drlapo is offline
post #5 of 24 (permalink) Old 05-15-2017, 08:16 AM
Main Motorcycle: '16 T120
NCT120's Avatar
I've been considering risers, or different handlebars altogether due to shoulder problems I've been having since I bought my T120 last summer. Right now I'm having physical therapy due to "frozen shoulder" and my riding enjoyment has suffered. Can't say for certain that it's because of the new motorcycle but I can't see any other reason for it.
Lioneagleman likes this.
NCT120 is offline
post #6 of 24 (permalink) Old 05-17-2017, 08:13 AM
Main Motorcycle: 2016 Bonneville T120
Duff-bucket's Avatar
I'd like to get some risers as well. Would these work on my '16 T120? ...
http://www.britishlegends.fr/en/hand...881&quantity=1
Duff-bucket is offline
post #7 of 24 (permalink) Old 05-17-2017, 10:29 AM
Just got a response from British Legends that these risers will NOT work with the new water-cooled twins due to the angled brackets. The new versions are in development but it will be a few months before they're available.
So I think I might try these:
https://roxspeedfx.com/collections/s...roduct-reviews
post #8 of 24 (permalink) Old 05-17-2017, 01:07 PM
Main Motorcycle: Triumph T120
muttskie's Avatar
Interesting. Hadn't seen these before. Please post on your results. Good luck!
2017 Cinder Red T120, Matris F15K fork kit, Bitubo WME shocks, Floating front brake discs, 39T rear sprocket, Triumph long haul windscreen, OEM LED turn signals, Comfort seat, Cruise control, and so on, and so on...
muttskie is offline
post #9 of 24 (permalink) Old 05-17-2017, 01:12 PM
Main Motorcycle: T120 black
ggfh's Avatar
These are regularly used on Tigers etc.
They should work if the diameter is correct. They are easy to adjust.
I have the SW-motech version on my Tiger, but those are a pain in the a.. to install.
But couldn't get the Roxx at that time.
ggfh is offline
post #10 of 24 (permalink) Old 05-17-2017, 01:48 PM
"These are regularly used on Tigers etc."
The only thing that concerns me with the Roxx is the angled top bracket on the T120. Do the Tigers have a similar bracket?
I sent them an email asking if it would work but haven't got an answer back yet.
Ace handle bar for T120 black Bkjoseph25 Water Cooled Twins Technical Talk 7 06-06-2016 10:07 PM
Handle bar risers on a Thruxton . Lightfoot Air Cooled Twins Technical Talk 0 10-09-2015 07:50 PM
How do I know if I need handle bar risers? SheaJ Tiger 800 - 800XC Mods & Workshop 10 06-27-2015 09:47 AM
