wobbling when no hands on handlebar - Triumph Forum: Triumph Rat Motorcycle Forums
 15Likes
post #1 of 66 (permalink) Old 04-17-2017, 10:40 AM Thread Starter
Main Motorcycle: 2016 T120 BLK
All was good till I have got the annual service done at dealership for my T120
Now a day later I see it's wobbling when removed my hands from the handlebar...
I know I shouldn't remove my hands from handlebar..
Is that an indication of some major issue around the corner?
Thanks
Capt
Captain_nd_coke is online now
post #2 of 66 (permalink) Old 04-17-2017, 11:30 AM
Main Motorcycle: Street Twin - 2016
rebel1735's Avatar
is it wobbling through out or at specific speed range?
rebel1735 is online now
post #3 of 66 (permalink) Old 04-17-2017, 11:45 AM Thread Starter
didn't notice.. probably arounc 40-60 miles range
post #4 of 66 (permalink) Old 04-17-2017, 02:53 PM
joeschmoe's Avatar
Maybe a wheel is out of balance? Perhaps a brake rotor is warped?
In any case, a fairly new bike like the T120 shouldn't wobble at any speed. I'd go back to the dealer and inform them of this.
joeschmoe is offline
post #5 of 66 (permalink) Old 04-17-2017, 03:30 PM
Main Motorcycle: '14 Bonneville T100
Location: Wilmington, NC - Winter, Downeast Maine - Summer
Other Motorcycle: '13 Street Triple
Extra Motorcycle: '07 Honda 919
If you have a lot of miles on your front tire, the tire itself could be the cause. I just went through this on my Honda 919 where the front end "no hands" wobble got worse and worse to the point that I could feel it even with my hands on the bars. It was worst between 40 and 60 mph. The front tire had something like 9000 miles on it but still had plenty of tread left. However, I mounted a new tire of the same size and brand and the wobble was gone. No wobble at any speed.
It's an annoying problem but it is not uncommon in motorcycles or in some cars and trucks.
saddlebag, Leo167 and runnerhiker like this.
Doberperson is online now
post #6 of 66 (permalink) Old 04-17-2017, 03:37 PM
Main Motorcycle: 2016 Triump Thruxton
saddlebag's Avatar
Other Motorcycle: 2015 Kawasaki Versys 1000
Or even if you don't just normal wear can be enough to cause it at various speeds. Fork mounted windscreens can also induce wobble.
The only thing I can think of that may be dealer related might be if he over torqued the steering stem. But I don't think they diddle with them until 10k miles and if you have that many miles on the tire, a little hands free wobble is almost a certainty.
runnerhiker likes this.
saddlebag is offline
post #7 of 66 (permalink) Old 04-17-2017, 03:39 PM
Main Motorcycle: 2014 Triumph Commander
One thing everyone should do when having someone other than yourself service a bike, go over every little detail to make sure it's right.
As soon as you get the bike back to the house, or in the parking lot go over everyone of the fasteners.
These guys can overlook a bolt, wrong torque etc. I would check the axle nut and pinch bolts to make sure they are secure. Air pressure as well.
I spoke to a chap who told me he had not checked air pressure on his Thunderbird in three years, I just walked away.
Red Devil
mikemm03 is online now
post #8 of 66 (permalink) Old 04-17-2017, 09:18 PM
It's the tire. Mine did the same thing from about 1000 miles up till 8500 when I changed the tires. Different brand of tire now no more wobbles at any speeds when I take my hands off the bars
Sent from my iPhone using Tapatalk
tofnbad is offline
post #9 of 66 (permalink) Old 04-17-2017, 11:18 PM
rebel1735's Avatar
caveat: this is purely out of experience on my 2016 ST.
assuming that the tyres are correctly inflated
first thing to do would be to check that the rear tire is mounted properly and chain etc. is aligned (easiest way i figured is to see if the rear tyre has an even contact patch i.e. its wearing out evenly on both sides moving out of the centre of the tyre)
second thing would be to check if the top bolt that is used to mount the engine dresser bar is torqued correctly to 80 Nm and not higher to 100 Nm or so in addition to what the member saddlebag suggested above regarding the steering stem
third thing to do would be to find a straight, even and relatively unoccupied road. take the bike to the offending speed i.e 40 - 50 mph (80 - 110 kmph) and let go of the handle bars for slightly longer and see if the wobble is developing into a full on tank slapper or if its just rocking a bit and then correcting itself.
post #10 of 66 (permalink) Old 04-18-2017, 12:06 AM
Main Motorcycle: '17 T120 Cinder Red
runnerhiker's Avatar
Other Motorcycle: '16 BMW R1200 RS
Capt, how many miles on that front tire?
Like others mentioned above, I have had this happen before and it was the front tire at the end of its life even though there appeared to be a lot of rubber left on the tire.
'17 T120 Cinder Red
'16 BMW R1200 RS
runnerhiker is offline
Sprint GT/ ST handlebar conversion kits chriscoote Sprint Forum 71 04-23-2017 12:45 PM
Triumph Black Logo Handlebar for T120 JHBoricua Water Cooled Twins Technical Talk 6 06-29-2016 10:01 AM
Loose clutch control assembly rotates on handlebar hinckleyNYC Air Cooled Twins Technical Talk 3 03-30-2016 03:50 PM
T-Bird front wheel balancing, hands up Suriya Thunderbird Cruiser Chat 7 02-03-2016 09:39 AM
Handlebar, riser torque settings cgpetrie Air Cooled Twins Technical Talk 4 02-22-2015 08:57 AM
