I want to relocate rear signals (got myself the smoked BC pair).
Initially wanted to mount on shocks with bracket, but I recently put panniers on, and this would affect their visibility.
Was thinking to use bracket and mount on grab rail bolts instead.
Was wondering if anyone has tried this, or anyone have any thoughts or suggestions.
Simple enough to fab up a right angle in some sheet metal and make your own as an alternative.
There are several places along the rear frame hoop that already have threaded holes on my Street Twin, and I suspect your T120 has the same or similar holes.
Looks real nice. Where did you get those relocation brackets from? Also, when I installed my bc retro (rear) and plug and play (front) on my t120 but the hazzard lights on flashes on right side. Did you do anything else to get everything to work?/Ulf
Used the brackets meant for suspension mounting from BC, and a few washers as spacers.
Hazard light work well without any modifications needed. Plug and play.
Starting to notice rust on screws and hardware on BC retro signals. I'll add some photos when I get a chance.
Anyone else experience quality issues with British Customs?
I've already have had a few other issues, such as hardware not tight enough to keep signal from leaning I did to it's weight, and products arriving scuffed up.
Wondering if others have experienced similar issues.
I grabbed a pair of the Motone signals installed them in the stock location. The just clear the housing so you can still have full visibility. THe signals came with long enough screws but if they hadn't I was just going to find a way make my own extenders. I was considering going the way you did but I decided to keep it as stock looking as possible.
Related Threads
Triumph Rat Motorcycle Forums
3.9M posts
167.7K members
Since 2002
