T120 Comfort Seat on my Street Twin
I have installed the Comfort Seat on my Street Twin.
For me it would be possible to fit the seat only lowering the fender as said in other posts. However, it would be necessary to lower too much for my taste (about 10mm I think), and I would have to buy longer screws (to make sure there is enough threads). Thus, I decided to make the surgery on the seat and take away part of the seat pan as described by wbarnier and MIK@. The staples are very easy to take off. I attached some photos to show the work. I removed around 10mm. The polypropylene of the seat pan is easy to work using a good quality box cutter. I used a Dremel with abrasive disc to make the first incision and the finish was made with the box cutter. I also took out the foam that was remaining out after the plastic material was removed. To staple it again you do not need to buy a stapler. Better to take it to an upholsterer. Probably he will staple it without charging you anything for it.
My impression about the comfort seat on my Street Twin:
Now the bike is perfect. The taller seat definitively improved the riding position providing best position for my knees (I have 32” inseam). Together with a 25mm handlebar riser I installed, the riding position is much better and now and I feel that my weight is in the right place. I found that the new bench is much softer and better to ride. It absorbs the unevenness of the floor much better than the original. Here in Brazil, even in a good city, the roads are very bad and we have all sorts of problems: irregularities, potholes and speed bumpers everywhere. I am thin and my butt can not absorb much on its own. For me it was worth every penny.
I found the seat has very good quality. Made in Spain. On the bottom it is possible to see that there is a gel pad below the passenger spot, and it is possible to believe that it also has some gel pad below the rider part (although it is not possible to see from bottom). It has water sealed seams. It also has 4 straps that can be used to attach some travel bags.
Best regards from Brazil!
