Full throttle readings
Low rpm ~ 14's
Mid rpm ~ 15-17
High rpm ~ 13's
I have added a bit more resistance as I prefer slightly rich to being too lean.
Runs strong now.
I posted this below on another thread you mentioned the dyno run on..........
"1) can you post a picture of the dyno chart please?
2) can you post some information about this resistor mod, for example what resistor did you use, and where and how you fitted it? (some pictures of this would also be very helpful)
I had to modify the Fuel ratio on my car once - built a mod using resisters and potentiometers - it went online with the Mas airflow sensor to fool the computer into thinking it needed less fuel - t was running too rich. Not sure how you would do this in reverse but I am sure it could be done - trick computer into thinking more air was passing that really is. Perhaps you could do this on the o2 sensor and make it run richer by adjusting the voltage.
One issue is that this assumes a linear voltage change at the sensor and some sensors outputs are not linear....
Triumph Western bars, familiar to some older folk here I expect.
Here's a pic showing opened cans.
Related Threads
Triumph Rat Motorcycle Forums
3.9M posts
167.7K members
Since 2002
