Added the Vance & Hines exhaust to my Street Twin - Triumph Forum: Triumph Rat Motorcycle Forums
 43Likes
post #1 of 82 (permalink) Old 02-28-2016, 11:43 PM Thread Starter
Main Motorcycle: 2016 Triumph Street Twin
Scrambler900's Avatar
Other Motorcycle: 2015 Vespa GTS 300 Super
Have added the "off road" Vance & Hines exhaust to my Street Twin, and put about 130 miles on the bike with the first test ride. While the stock exhaust looks and sounds super, the Vance & Hines looks equally great and really enhanced the bike's performance and sound. This is the exhaust that compliments the Street Twin's mid-range torque.
Installation was rather straight-forward (assuming you've swapped out a Triumph Bonneville or Truxton exhaust before). There are a few rubber mounting pieces that need to be removed from the stock slip-ons and replaced onto the Vance & Hines set, as you don't get a second set. One bit of advice about the need to remove the rear passenger foot pegs, as required. In order to remove the pegs and swap out the exhausts, you actually have to first disassemble the pegs down to the small ball bearing, small spring and metal clip. That is because in order to briefly remove the pegs, it takes an allen head wrench and another wrench, and there is insufficient room to fit the allen head without taking the peg completely apart. A little different and slightly more time consuming compared to removing passenger pegs on a 2015 and earlier Bonneville or Truxton. If not done very carefully, it's really easy to send the small ball bearing and spring shooting out and being lost. (In my case, briefly hidden till found as I crawled around on my knees looking for it on the garage floor.)
The workmanship of the stock exhaust system and the Vance & Hines are identical, so I assume its all made by the same company. The Vance & Hines set is about 3" shorter in length. Also, the Vance & Hines system is considerably lighter in weight, perhaps by 40%. I am guessing at 40%, but I feel that's about accurate. The weight savings is very noticeable between the two. I was really glad to gain this weight reduction. I didn't have a set of scales to measure, however.
The stock system has no removable baffle. Once removed, I could look from end to end through the inside. There are no internal obstructions. However, the inner wall of the stock exhaust tube running from end to end looked sealed with respect to there being no obvious openings to the outer chamber. Maybe there is one, but I couldn't see it. In contrast, the Vance & Hines has a small removable metal clip holding in a simple snap ring. Removing that allows for the 3" to 4" baffle to come out. It looks a lot like a trumpet mouth piece. When looking through the Vance & Hines exhaust, you also easily see end to end, and, the entire inner chamber is perforated with plenty of holes from end to end, incorporating the outer chamber as well. With the baffle removed, the end of the exhaust opening is larger than stock and much better looking. (There is no way to "bore out" the Street Twin's stock exhaust and make it compatible with the Vance & Hines, as can often be done with stock Harley-Davidson exhausts verses Screaming' Eagle exhaust upgrades). Stock verses Vance & Hines Street Twin exhausts look almost the same on the outside, but differ totally on the inside.
The dealer told me I would need to bring the bike in for the required ignition remap, and until I do, I may experience some popping on deceleration, etc. But I can report that the bike ran super today with zero popping, stumbles or other indication of an immediate need for the remapping to be done. I was pleasantly surprised about that. In fact, the Street Twin performed so well it makes me feel the Vance & Hines exhaust is ideally paired to make full advantage of the mid-range torque. I have no access to a dyno for the moment to document any performance gains. But I can say that the bike's quickness from a stop up to 90 mph (before shifting into 5th) easily beats my past new classic triumph Truxton's and Bonnevilles that all had Predator or Arrow exhausts, air box removed, K&N air filters, etc. (Let the doubters' comments begin, but I know what my Street Twin delivers versus my previous Triumphs).
In terms of sound, the Vance & Hines set is a little louder than stock when started, but not obnoxious at all. A very deep resonance that is quite different from Predators or Arrow systems. However, if you give the Street Twin full throttle, the Vance & Hines exhaust barks with a very deep v-twin sound, a lot like what I've heard on an Aprilia, Buell or Ducati at the VIR track. After 4 hours, it didn't wear out my ears the way Predators on a Truxton would give - just my opinion.
Attached are two photos - one of my bike with the shorter Vance & Hines exhaust (and Triumph rubber tank knee pads mounted), and the other photo showing the inside of the exhaust.
I highly recommend the Vance & Hines exhaust and its a worthwhile accessory worth the cost.
ID:	342514   Click image for larger version
Stay cool, like Steve McQueen
My photo web site is http://triumph.smugmug.com
Scrambler900 is offline
post #2 of 82 (permalink) Old 02-29-2016, 12:03 AM
Main Motorcycle: 2016 Triumph Thruxton R
SirCuffsalot's Avatar
Beautiful bike... And great, in depth, write-up... Thanks for taking the time to do that.
BGM360 and deliriumskid like this.
SirCuffsalot is offline
post #3 of 82 (permalink) Old 02-29-2016, 03:47 AM
Main Motorcycle: 2014 Bonneville Standard
Looks nice. Got any videos?
Bonneville63 is offline
post #4 of 82 (permalink) Old 02-29-2016, 03:09 PM
Main Motorcycle: 2016 Thruxton 1200, green
Youngtimer's Avatar
I've ridden the bike with the German version of the Vance & Hines (are there any differences?) and came to the conclusion that this Street Twin is absolutely awesome because there are so many good things coming together. All of them works, maybe not on paper (only 55hp) ... but in the real world, on real roads.
Therefore my recommendation: If you have a chance to ride this new Triumph, please do it. Even if it looks bland on paper.
I hear thunder but there`s no rain.
Youngtimer is offline
post #5 of 82 (permalink) Old 02-29-2016, 03:21 PM
Main Motorcycle: '10 Bonneville SE
Other Motorcycle: '07 Ducati GT1000
Extra Motorcycle: After the divorce
Originally Posted by Youngtimer View Post
That plate hurts my eyes
Whatshisface likes this.
RIP 2010 Bonneville Base
RUPNOK is online now
post #6 of 82 (permalink) Old 02-29-2016, 04:34 PM
Main Motorcycle: Triumph Bonneville T120
Other Motorcycle: Moto Guzzi Breva 1100
Nice looking bike and exhaust. Thanks for the write up.
menzies is offline
post #7 of 82 (permalink) Old 02-29-2016, 10:32 PM
Main Motorcycle: 2016 Tiger 800 XRT
dbqfan's Avatar
The knee pads really make a huge difference in the overall appearance of the bike!!!!!!
Oldguy likes this.
dbqfan is offline
post #8 of 82 (permalink) Old 02-29-2016, 11:33 PM Thread Starter
I have always added knee pads to my new classic Triumphs - I've have several of these bikes since 2005. The pads on my Street Twin are the current ones as found on 2015 and earlier Bonnevilles, not the "new" style as pictured in the few available photos of the new water cooled bikes. Frankly, I don't like the looks of the new design, judging from those photos, and so I went ahead and added the existing knee pads.
post #9 of 82 (permalink) Old 03-01-2016, 10:54 AM
Main Motorcycle: 2000 Triumph Adventurer
jrat's Avatar
About to order mirrors and the tank pads. I agree with you that the newer pads don't look as good as the old one.
Any difficulty in applying the old to the new smaller tank?
jrat is offline
post #10 of 82 (permalink) Old 03-01-2016, 09:55 PM Thread Starter
I've added Triumph tank knee pads to 4-5 previous Scramblers, Bonnevilles & Truxtons I've owned. Putting them on the Street Twin was exactly the same procedure, and I spent a few minutes measuring, eyeballing the ideal location, and adding some black electrician's tape markers as a guide. If you've never done this before, be careful, as you only get ONE CHANCE once you pull off the thin wax paper covering the adhesive and apply it to the tank. It sticks instantly and can't be repositioned.
The photos I have found on line of the new knee pad design not only showed two different cosmetic changes (that I didn't like), but, also seems to show a smaller knee pad. I still have not seen one in person so I cannot be sure. But I can say the familiar rubber knee pads fit just fine regarding size, and laying flush against the Street Twin's tank.
I saw (and heard) the Street Twin today 2wheel_Ted Air Cooled Twins Talk 26 10-01-2016 12:29 PM
Street Twin's Vance & Hines exhaust option Scrambler900 Air Cooled Twins Talk 17 09-28-2016 10:00 AM
Seeking subjective advice on trading in a 2015 Bonneville SE for a 2016 Street Twin Scrambler900 Air Cooled Twins Talk 94 02-29-2016 07:04 PM
Video: Street Twin (w/ Vance & Hines) and Thruxton R running! spastikmonkii Air Cooled Twins Talk 5 12-15-2015 01:40 AM
MCN Street Twin initial ride review Sofiaspin Air Cooled Twins Talk 9 12-14-2015 07:04 PM
