Cheap penetrating fluid - Triumph Forum: Triumph Rat Motorcycle Forums
Vintage Technical Tips & Tricks Technical and maintenance tips and links. DO NOT POST YOUR QUESTIONS HERE!! Please post questions to the general forum.
Old 10-02-2012, 11:00 PM   #1 (permalink)
Main Motorcycle: 1971 TR6
Looking for a cheap alternative for penetrating fluid, try using a 50-50 mix of acetone and ATF (automatic trans fluid). Keep it away from plastics. Use a metal can to store it, similar to a plunger type oil can or a oil can like your grandpa used to use (push-in bottom).
Need a loosener for threaded bolts and nuts, warm it up first with heat, then press a white paraffin wax candle to the bolt. Liquid paraffin wax acts just like squirrel piss and will run down the threads because of low viscosity.
alittle1 is offline   Reply With Quote
Old 10-03-2012, 06:31 AM   #2 (permalink)
Main Motorcycle: Tiger Cub 1957
Other Motorcycle: T140 1982
Cheers alittle1.
I think you mentioned your patent fluid before and I gave it a go. Excellent results, I now have a bottle handy in the workshop. Thanks.
Doug748 is online now   Reply With Quote
Old 11-01-2012, 06:12 AM   #3 (permalink)
max
Main Motorcycle: Thunderbird Storm
Extra Motorcycle: 1970 TR6C, Matchless G80C
Yep its better than over the counter penetrating fluid for sure. Used it for years.
max is offline   Reply With Quote
Old 11-01-2012, 06:44 AM   #4 (permalink)
Main Motorcycle: T100
Dan McGrath's Avatar
Other Motorcycle: basket case Honda Scrambl
Common Diesel fuel.
Dan McGrath is offline   Reply With Quote
Old 11-08-2012, 08:23 PM   #5 (permalink)
Main Motorcycle: 1978 Bonneville T140V
Morris the Cat's Avatar
Originally Posted by Dan McGrath View Post
Common Diesel fuel.
常见的柴油燃料。
for our chinese friends!
Morris of Main Street
Morris the Cat is offline   Reply With Quote
Old 12-11-2012, 01:33 PM   #6 (permalink)
A friend of mine sent me this email to update me on what he had found out about my concoction, gives you a better idea, now.
Penetrating Oils Machinist's Workshop Mag recently published some information on various penetrating oils. The magazine reports they tested penetrates for break out torque on rusted nuts.
They are below, as forwarded by an ex-student and professional machinist. They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a "scientifically rusted" environment.
*Penetrating oils ........... Average torque load to loosen*
No Oil used .................. 516 pounds
WD-40 ..................... ....238 pounds
PB Blaster ................... 214 pounds
Liquid Wrench ...............127 pounds
Kano Kroil .................... 106 pounds
ATF* - Acetone mix..........53 pounds
The ATF-Acetone mix is a "mix-your-own-brew" -- 50 - 50 automatic transmission fluid and acetone. Note this "home brew" released bolts better than any commercial product in this one particular test.
Our local machinist group mixed up a batch and we all now use it with equally good results. Note also that "Liquid Wrench" is almost as good as "Kroil" for about 20% of the price.
Steve from Godwin-Singer says that ATF-Acetone mix is best, but you can also use ATF and lacquer thinner in a 50-50 mix.
*ATF = Automatic Transmission Fluid
Old 12-16-2012, 07:07 PM   #7 (permalink)
Main Motorcycle: 1976 T140v
Other Motorcycle: GSXR 750
Extra Motorcycle: T 100r in the queue.
Great tip, those results are impressive.
" KEEP 'ER LIT LAD "
whatsthat is offline   Reply With Quote
Old 01-11-2013, 07:30 AM   #8 (permalink)
Main Motorcycle: Twenty One
Other Motorcycle: vespaholic
I like Ed's Red:
Equal Parts of: ATF, Acetone, Mineral Spirits, and Kerosene.
I've substituted Tiki Torch Citronella for the Kero on ocassion and also used "hot" type laquer thinner for acetone on ocassion. (Note: "hot" describes a laquer thinner you would use on a very cold day). All dangerous stuff...use care and common sense.
gutz is offline   Reply With Quote
Old 02-21-2013, 10:25 PM   #9 (permalink)
Main Motorcycle: 79 T140E
during storage, wouldn't the acetone evaporate.
79woodsie is online now   Reply With Quote
Old 02-22-2013, 11:34 AM   #10 (permalink)
Probably, if you store it in a frying pan. I believe the original post says to store it in a metal can as it would probably diminish somewhat in a plastic type container. NOTE: Acetone is sold in metal containers and shelf life is pretty good, at least at my Home Depot.
What spray oil is super penetrating? dazco Maintenance & Workshop Talk 6 08-20-2011 07:54 PM
Cheap Triumph, very cheap Jayell Twins Talk 10 08-12-2011 12:13 PM
Cheap panniers - too cheap to be any good? FlyBri Twins Technical Talk 3 06-20-2007 02:34 PM
Help me be cheap....where is "cheap bastard"? nyamwegi Speed Triple Forum 3 06-20-2007 10:06 AM
Which brake fluid? DOT 4 or 5.1? Blissed Maintenance & Workshop Talk 2 04-08-2006 10:15 AM
