A Tip on Spark Plugs. - Triumph Forum: Triumph Rat Motorcycle Forums
Vintage Technical Tips & Tricks Technical and maintenance tips and links. DO NOT POST YOUR QUESTIONS HERE!! Please post questions to the general forum.
Old 04-03-2012, 09:26 AM   #1 (permalink)
Main Motorcycle: 1977 T140V
Ohio-Rider's Avatar
Other Motorcycle: 1949 Ariel SQ4
Extra Motorcycle: 1945 WL (Civilian)
Some thing of interest I read this morning. It seems that once a modern spark plug has been flooded with fuel they become less affective. It has something to do with the glaze put on them. So guys, if you flood your engines, change your plugs. Wiping them off is of little value once the have been wet.
http://www.gsparkplug.com/shop/fouli...ampion-vs-ngk/
Ohio-Rider is offline   Reply With Quote
Old 04-03-2012, 10:59 AM   #2 (permalink)
Main Motorcycle: '77 Bonneville T140V
Garioch43's Avatar
Rumour generated by the spark plug manufacturers perhaps???
Just call me synical.
Sam Murray
Aberdeen, Scotland
Garioch43 is offline   Reply With Quote
Old 04-03-2012, 01:16 PM   #3 (permalink)
No, it's absolutely true.
I had a tricked out Honda CB550 that would only run for about a week on brand new ND "U groove" plugs. Even careful bead blasting resulting in obviously/noticeably inferior performance. New plugs would again work great for another week. New plugs of other brands (Champion, NGK, etc.) resulted in poor performance. ONLY ND plugs would work.
I think I still have 20 or 30 pounds of those plugs in a box somewhere...
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 04-03-2012, 01:17 PM   #4 (permalink)
Ohio-Rider's Avatar
That just may be Sam. I’ve never had a problem cleaning up wet plugs on a motorcycle and reinstalling them, BUT, I have had trouble with them after flooding them on small engine tractors.
I could wipe them off and even put a lighter to them to burn off the fuel, but they failed to fire the engine once reinstalled. Put in a fresh set and boom, the engine fires right up. Maybe some other guys have had like experiences after wetting their plugs. It does tweak my curiosity though.
Old 04-03-2012, 01:19 PM   #5 (permalink)
Main Motorcycle: 1974 T120V
Other Motorcycle: 1972 T120R
Extra Motorcycle: Kawasaki ZZR1100
I have found that Champion plugs will clean up, but once NGK have been fouled, then they are scrap.
Mark
mark61120 is offline   Reply With Quote
Old 04-03-2012, 01:59 PM   #6 (permalink)
I've had mixed results with cleaning Champions on my old Triumphs...
GrandPaulZ
Born Again Bikes
My Photo album
Old 04-03-2012, 03:17 PM   #7 (permalink)
Main Motorcycle: Thunderbird
Stratofaster's Avatar
Other Motorcycle: 1970 Bonneville
I've had some success cleaning fouled spark plugs with disc brake cleaner. Gumout doesn't work--it leaves a film.
Cleaned plugs still aren't as good as new, however.
Stratofaster is online now   Reply With Quote
Old 04-03-2012, 06:18 PM   #8 (permalink)
Main Motorcycle: The one between my legs
Snakeoil's Avatar
Other Motorcycle: '76 Triumph T140V
Extra Motorcycle: Yes
I used to have a plug cleaner that came from an old Buick dealership. It was sold by AC and had a big AC sticker on it. It was a sand blaster.
But then they said that sand blasting plugs ruined them so I sold it in a garage sale.
I've cleaned fouled plugs with wire brushes for years. Never had a problem. Maybe one or two that I ended up buying a new plug. But for the most part, only time I've had noticeable plug problems was on 2-stroke dirt bikes years ago.
I even keep old plugs as emergency spares if they look decent. Maybe I've just been lucky all these years.
regards,
Rob
Snakeoil is online now   Reply With Quote
Old 04-03-2012, 06:44 PM   #9 (permalink)
Main Motorcycle: 1978 Bonneville T140V
Morris the Cat's Avatar
Champion N3C (Copper -core) plugs have given good service here.
Local NAPA had 2 sets only- got em' both.
Good tip about not sandblasting - unlike the good old days!
Morris of Main Street
Morris the Cat is online now   Reply With Quote
Old 04-03-2012, 10:54 PM   #10 (permalink)
Main Motorcycle: Kawasaki W650
Other Motorcycle: lots of Triumphs
Since the new spark plugs no longer have insulator glaze, what's the problem with blasting them? I use a walnut shell blasting medium.
motobob is offline   Reply With Quote
New Ignition Coil, Spark Plug Wires and Iridium Spark Plugs...better performance? brownbomber Twins Talk 15 10-27-2009 03:25 PM
Spark plugs? awegs955i Daytona Deliberations 11 02-07-2009 01:25 AM
Spark Plugs BRG-BIRD Hinckley Classic Triples 2 08-24-2008 05:13 PM
Spark Plugs for a '54 T-110 Stormin Classic, Vintage & Veteran 3 08-22-2006 08:39 PM
spark plugs schmark plugs DaleE Hinckley Classic Triples 6 10-25-2005 10:54 AM
