Stator Question. Two or Three wires? - Triumph Forum: Triumph Rat Motorcycle Forums
Vintage Technical Tips & Tricks Technical and maintenance tips and links. DO NOT POST YOUR QUESTIONS HERE!! Please post questions to the general forum.
post #1 of 5 (permalink) Old 04-11-2011, 07:20 PM Thread Starter
Main Motorcycle: 1979 Bonneville T140E 750
I'm a bit confused on the stator. To start off I have a 79 Bonneville T140E 750 cc. There are three wires/terminals that go from the rectifier to the alternator, as least as far as I understand. These three are colored green/black, green/white and green/yellow. I ran some tests and suspected the stator to be faulty. I took it out and then I noticed there were only two wires coming from the stator when I thought there should be three.
I bought this bike last summer and I always knew there was this extra wiring just hanging around where snap connectors are from the alternator to the harness. When I unraveled the electrical tape I saw that only two of those wires actually were connected to the alternator and the third one (the one i always noticed hanging around) didn't connect to anything? Now I know the guy told me he replaced the entire harness on the bike and what I'm trying to figure out is where that third wire is supposed to go? I thought maybe the stator was from a different bike that only used two wires and he adapted it somehow? Or is that how it's supposed to be? Because I'm looking at a picture of the stator where I was about to order mine from and noticed those only have two wires as well?
I'm really confused. Any help is surely appreciated. Thanks.
zap-uh is offline
post #2 of 5 (permalink) Old 04-11-2011, 09:01 PM
Main Motorcycle: 66 TR6
coloradobob's Avatar
Other Motorcycle: 73 t150
Extra Motorcycle: some TR7's and T 150's
1 or 3 phase stator
You may have to verify whether you have a single-phase (2-wire)or later 3-phase (3-wire)alternator. Did a wire break or is it a good single phase. Your regulator will need to match your stator. It gets interesting investigating repairs by the PO. I think there is some reduced charging by using 2 wires of a 3 wire stator, but I don't know about the other way 'round. If the stator is functional but wrong, replacing the rectifier/zener with solid state single phase might be an option. Sparx makes stators. Bob
coloradobob is offline
post #3 of 5 (permalink) Old 04-11-2011, 09:48 PM Thread Starter
I think I'm supposed to have a 3-phase(3 wire) alternator. This is my assumption based on the Triumph Shop Manual, the wiring diagram and the fact that there's three wires coming from the rectifier. But this current stator that I pulled out is a single-phase (2-wire). One of the wires did break where the snap connectors should be. So I have a 2 wire set up where I should have a 3 wire set up.
When you say my regulator has to match my stator, are you referring to the zener diode pack?
Here's what the shop manual says:
The alternator produces 3 phace AC, rectified to DC by a 3DS5 rectifier and voltage controlled by a 2CDP zener diode pack.
zap-uh is offline
post #4 of 5 (permalink) Old 04-11-2011, 09:56 PM
I'm just saying that they both need to be three phase. I't doesn't make much difference in the long run if the alternator stator is incorrect or just has a broken wire. http://compare.ebay.com/like/3602986...fdbd485&itemid At least they're cheaper than when another Lucas was the only choice. http://cgi.ebay.com/ebaymotors/ws/eB...2166&viewitem=
Bob
post #5 of 5 (permalink) Old 04-11-2011, 09:59 PM Thread Starter
Awesome. Thanks a lot for your help, man.
zap-uh is offline
Wires off Alternator Question Landshark Classic, Vintage & Veteran 3 11-21-2009 02:03 AM
Stator Cover Question Kovac Triumph SuperSports 4 06-21-2009 12:53 PM
Sparx Stator and regulator question deathwish Classic, Vintage & Veteran 29 04-30-2009 06:32 PM
2004 Daytona 600 Stator question daytonaguy Triumph SuperSports 4 04-02-2009 04:30 PM
Stator test correct? Will S4 stator work? redl1nerpm Triumph SuperSports 7 10-10-2008 12:44 AM
