Pre-unit Case Repair - Triumph Forum: Triumph Rat Motorcycle Forums
Vintage Technical Tips & Tricks Technical and maintenance tips and links. DO NOT POST YOUR QUESTIONS HERE!! Please post questions to the general forum.
Old 02-08-2011, 12:40 AM   #1 (permalink)
smurdy's Avatar
I'm considering restoring a '56 T110 that my Dad has had sitting in a shed for more than 30 years. The biggest concern I have is that the case is cracked right at one of the cam bearings. I've seen a lot of cases on e-bay that have this same problem so I assume it is a common one.
Is it possible to effectively repair a crack in this area by welding the case? If so, can anyone recommend a shop in the So Cal area with experience doing such a repair? My Dad used to have a shop specializing in British bikes so I think he can help with the rebuild but welding aluminum is something I'd rather leave to an expert.
smurdy is offline   Reply With Quote
Old 02-23-2011, 05:02 PM   #2 (permalink)
Main Motorcycle: T 140 es
Other Motorcycle: TRITON 650 1961 GILERA500
Can you put some pics of this crack? I have several pre unit engine cases and dont see any cracs. But I run succesfuly engine with welded hole made by broken rod,on front timing side cases!
mcrmirko is offline   Reply With Quote
Old 02-23-2011, 08:01 PM   #3 (permalink)
Main Motorcycle: 72 TR6 100,000 miles
coloradobob's Avatar
Other Motorcycle: 73 t150
Extra Motorcycle: 73 TR7RV big bore
Welding a case
Due to possible distortion from the heat of the welding process, it is wise to leave adjacent cases, cams, etc intact and torqued. The cam needs to turn freely throughout the process. I had mine done by a local shop in business since the 60's. They showed me a repair that had 10-times as large a hole as mine. Bob
coloradobob is offline   Reply With Quote
Old 02-24-2011, 09:10 PM   #4 (permalink)
smurdy's Avatar
The bike is still in the shed so I can't get a pic now but I'll post one when I can get over there. I may be mistaken about the cracks I saw on ebay--could just be bad pictures.
As far as this crack, the Old Man says it was caused when someone (not him) tried to replace a stud and somehow cracked the case right at the cam bearing.
Old 02-24-2011, 09:12 PM   #5 (permalink)
smurdy's Avatar
Thanks for the advice Bob, that makes a great deal of sense. I'll see if I can locate a local person with that level of experience to fix it.
Pre-unit 650, and 1966 650 unit heads/jugs interchangable? becket Classic, Vintage & Veteran 33 02-08-2011 06:48 PM
Pre Unit Primary Chain Inner Case Pattern / Bower Powerbox without Battery jasonlewis100 Classic, Vintage & Veteran 0 10-08-2010 10:43 AM
Crank Case / Primary Chain Case - Seals Help Will71bonneville Classic, Vintage & Veteran 8 02-12-2010 01:48 PM
English 101 DVD - unit & pre unit Triumph & unit BSA Motorcycle Maintenance DVD lowbrowcustoms Maintenance & Workshop Talk 2 08-23-2009 02:48 AM
English 101 DVD - unit & pre unit Triumph & unit BSA Motorcycle Maintenance DVD lowbrowcustoms Lowbrow Customs 0 08-17-2009 12:48 PM
