gasket sealant or not ??? - Triumph Forum: Triumph Rat Motorcycle Forums
Vintage Technical Tips & Tricks Technical and maintenance tips and links. DO NOT POST YOUR QUESTIONS HERE!! Please post questions to the general forum.
post #1 of 27 (permalink) Old 02-07-2011, 03:26 PM Thread Starter
Main Motorcycle: 1966 Triumph Bonneville
Other Motorcycle: 1994 BMW Airhead
Extra Motorcycle: several british bikes
When rebuilding these old Trumpets, do you pros out there use gasket sealant on all the gaskets or none of them ?? Primary?, timing cover?, inner and outer trani covers ?? Thanks.
catchalot is offline
post #2 of 27 (permalink) Old 02-08-2011, 03:20 AM
Main Motorcycle: Kawasaki W650
Other Motorcycle: lots of Triumphs
I use Gaskacinch to hold the primary gasket to the cover.
Everybody pretty much uses ThreeBond #4 (the grey stuff aka Yamabond, Hondabond, etc.) on the case joint surfaces.
I think everywhere else you can use dry gaskets. Some covers didn't come from the factory with gaskets, but are now supplied aftermarket like the inner and outer transmission cover. If you choose not to use the gaskets, use the ThreeBond.
I have also used it in place of the primary gasket in an emergency and it worked just fine.
I'm probably the only one who does this, but I don't use the rocker arm O-rings, but use ThreeBond instead.
motobob is offline
post #3 of 27 (permalink) Old 02-08-2011, 03:39 AM
Main Motorcycle: '59 thunderbird
Other Motorcycle: '95 Thunderbird
On recommendation from a local Tri mechanic years ago, I use Three bond White (hi temp silicone) as well as Three Bond Gray. The white stuff is dear to me here in Australia ($45.00 for 100g) but I have found it worth it. I use it where I think I am not likely to get away with the gray - rocker boxes for example.
We can't always control what happens to us.
What we do about it is always up to us.
loctitekid is offline
post #4 of 27 (permalink) Old 02-08-2011, 11:07 AM
Main Motorcycle: 72 T120R
Buckshot1's Avatar
primary case...grease both sides
timing case....dry..used one to get a tad more clearance for 4 valve pump
oil pump.... wet with oil at assy
oil junction block...wet with oil
alternator cover...ThreeBond, Permatex, etc to cover side
rocker boxes...dry...use the good sandwich gaskets, you'll probably be able to reuse them with a little care
copper washers...fully anneal and flat sand
inspection caps...soak in oil and good luck...I'm making up some copper for those, will post results...I think Webby has got his to not leak.
ThreeBond seems fairly easy to clean up with a bit of B-12 or acetone. Except for the drive sprocket, I won't use silicone.
Michael
72 T120R
builder of plunger drill jig
Buckshot1 is offline
post #5 of 27 (permalink) Old 02-08-2011, 11:54 AM Thread Starter
Thanks for the info !!
post #6 of 27 (permalink) Old 02-09-2011, 02:01 PM
Other Motorcycle: Triumph Speedtriple
I'm with Buckshot on this one, I used "Wellseal" (a non drying type sealant) for the case joint. For everything else get good quality gaskets and smear them with high temp grease, that includes the head gasket.
The only places I have RTV type sealant is a light smear on the gearbox output shaft to stop gearbox oil from leaking down the splines.
As for the rocker covers, I've installed 'O' rings everywhere, they work well for the large tappet access holes but the smaller ones on the side would still weep a little oil so there's a little RTV in there too, it also stops them from vibrating loose.
Webby
Webby is offline
post #7 of 27 (permalink) Old 02-09-2011, 09:30 PM
Buckshot1's Avatar
Webby,
Did you seal the boxes to the head with o-ring as well? Way cool if you did. I would like to have just about everything done with o-rings. Probably will remain a fantasy.
Michael
72 T120R
post #8 of 27 (permalink) Old 04-11-2012, 05:10 PM
Main Motorcycle: '73 TR7RV (Tiger) 750
Other Motorcycle: Kawasaki ZZR1200
Question on using gasket sealant on gaskets.
Hi all,
I see this info given:
I read to keep the cylinder barrel gasket dry, and what BuckShot1mentions is great info. Is it ok to use a little permatex Copper Spray-A-Gasket on it?
By grease on the primary (outer) cover - I'm curious why grease vs. dry, or a light Spray-a-gasket would be used.
Gearbox case - do you recommend a dry gasket?
thanks
marsza is offline
post #9 of 27 (permalink) Old 04-11-2012, 08:22 PM
Buckshot1's Avatar
Grease will soak into the gasket and swell it as well as aiding removal without tearing later. My opinion only. I would also grease gearbox gasket. YMMV.
Michael
72 T120R
post #10 of 27 (permalink) Old 04-12-2012, 02:20 AM
Main Motorcycle: '72 Bonneville
RetroRod's Avatar
Other Motorcycle: Suzuki GSX1400
Webby
Me too Webby, though many swear by their RTV sealants.
As the "Enlightened Ones" know, crankcase pressure is the real villian when it comes to niggardly leaks. RR
You have enemies? Good. That means you've stood up for something, sometime in your life. (W S Churchill)
RetroRod is offline
Exhaust sealant MAD1 Air Cooled Twins Technical Talk 11 01-23-2011 08:01 PM
Exhaust Sealant morvegil Sprint Forum 1 09-21-2010 05:40 PM
Gasket sealant or not? Vince C Classic, Vintage & Veteran 10 08-20-2009 08:36 PM
Underseat tray? Type of gasket sealant for sump gasket? ladyhawk Daytona Deliberations 0 09-11-2008 05:30 AM
gasket sealant for Tbike pipes? dazco Air Cooled Twins Talk 4 09-06-2005 10:58 PM
