Cylinder bore - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Vintage Technical Tips & Tricks Technical and maintenance tips and links
Old 03-09-2010, 11:33 AM   #1 (permalink)
Newbie
Cylinder bore
Hi I have a triumph 3ta can anyone tell me what is the max. size the cylinder can be bored out to.
ifras is offline   Reply With Quote
Old 03-09-2010, 05:27 PM   #2 (permalink)
Favourite Bike: Vincent
Marc Beaudry's Avatar
Other Motorcycle: trident
Extra Motorcycle: bonneville t120
call your local parts supplier and find out the largest over pistons they stock - thats usually the max overbore...
or are you asking the the max. overbore the liner will take ?
Marc Beaudry is offline   Reply With Quote
Old 03-09-2010, 07:01 PM   #3 (permalink)
Favourite Bike: 1966 Thunderbird
Other Motorcycle: 1996 Trophy
I believe Triumph supplied a max of +.050 on most all models. Some Jap and Italian accessory makers supplied +.060 on some bikes. You don't want to bore unless you have to. There are all sorts of ways around this for a not-ridden-very-often classic.
Are you considering this because the bore is rusty, oval, tapered, or simply loose with the pistons?
The GABMA newsletter. What's on the back of your toilet?
http://www.gabma.us/
GABMA is offline   Reply With Quote
Old 03-10-2010, 06:01 AM   #4 (permalink)
Newbie
The piston has +0405L stamped on it,when I checked the piston ring in the bore the gap was about 2mm. I do not have any precise measuring instruments so I cant say what size the bores are.
Old 03-10-2010, 09:01 AM   #5 (permalink)
Lightbulb Don't do anything rash....
Ring gap is the worst possible way to gauge bore diameter.
1) No doubt the rings on a bike that old have a large gap. That's OK, even expected. New rings are easy to acquire because piston rings are somewhat standardized. You simply need to find the bore (usually in mm) and have an engine specialist cast around for another modern engine with the same bore. You might even be able to do that on-line these days. Finding rings by bore dia is much easier that looking for official 3TA ring sets!
2) Then as to the pistons, turn them up-side-down in the bore, and see what size flat "feeler gauge" you can put between the front of the skirt and the front of the bore. In other words, measure your front-to-back clearance at the bottom of the piston at a point in the bore about 1/2" down from the head gasket.
Tell us what those results are.
Old 03-22-2010, 07:07 PM   #6 (permalink)
Newbie
cylinder bore
Itook the engine block to an Engineering company and they told me the pistons were the wrong size they should be +60.They have supplied me with the correct pistons and rings so now its back to my garage,thanks everyone .
Old 04-07-2010, 07:34 PM   #7 (permalink)
Exclamation Watch out
Most shops these days will simply sell you what they have in stock, and not what you actually need. Boring is a real big thing for shops because they get to rip you off on pistons, rings, bore job, which some times doesn't even need doing.
On these old bikes is highly unlikely that you'll actually ride the bike 20,000 mile to find out, so they'll make the sale and never see you again.
Repair of old bikes as practiced by the bulk of the players is simply a con game. If you don't believe me ask for the cylindricity and ovality measurements of your cylinder. They probably won't have them because they probably never measured the cylinder.
Old 04-08-2010, 08:54 AM   #8 (permalink)
Favourite Bike: 1971 T100C
Other Motorcycle: 2011 Triumph 1700 Storm
My machinest gave me so many measurements for each cyl I had to ask him to explain what it all meant. Basically my bores were pear shaped, out of round and oval. It was facinating watching him take the measurements with his equipement. Plus it is a little reassuring when you are in the company of someone that knows what they are doing and is willing to explain it to a stranger.
We have lots of shops in my area but I wasn't happy with the "just leave it with us and we'll take care of it" approach.
I finally got a solid lead after a month of asking around. Local member of the Vintage Motorcylce club pointed me in the right direction.
toxic is offline   Reply With Quote
Old 04-08-2010, 12:22 PM   #9 (permalink)
Favourite Bike: '67 Triumph Bonneville
Absolutely best to find a machinist that works on MOTORCYCLE engines.
My friend has been in the business for over 30 years, and is a Harley collector. He's never done me (or anyone else) wrong, that's why he's still in business.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 04-09-2010, 01:31 AM   #10 (permalink)
Favourite Bike: '72 Bonneville
RetroRod's Avatar
Other Motorcycle: Suzuki GSX1400
I truly wonder why we offer up advice sometimes, when all they have to do is run down to the nearest machine shop (that has never seen a set of Triumph barrels before), and get all the solid advice from them. RR
"A cynic is a blackguard whose faulty vision sees things as they are, and not as they ought to be."
Ambrose Bierce (1842-1914)
http://www.reinstatehank.org/
RetroRod is online now   Reply With Quote
Gap between cylinder head and cylinder barrel. cbm206 Classic, Vintage & Veteran 7 09-07-2009 03:02 PM
Cylinder Bore Tolerances BuckeyeRat Vintage Technical Tips & Tricks 10 04-17-2009 05:40 AM
650 tiger cylinder bore questions????? bobberguy0341 Classic, Vintage & Veteran 8 02-02-2009 01:18 AM
Front Bore Master Cylinder Britrover Twins Talk 0 08-08-2005 03:14 PM
Triumph 650 big bore cylinder panic Classic, Vintage & Veteran 5 12-13-2004 10:54 PM
