1968 T100C timing cover - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Ontario TourismHonda PowersportsMotorcycle.com Classifieds!SportbikeTrackGear
Vintage Technical Tips & Tricks Technical and maintenance tips and links
Old 03-07-2010, 10:14 AM   #1 (permalink)
Favourite Bike: 1970 Bonneville
Other Motorcycle: 1968 T100C
Extra Motorcycle: 1967 Daytona
When removing the timing cover, do you need to remove the contact breaker assembly or can you simply remove the 8 pozidrive screws?
TampaTriumph is offline   Reply With Quote
Old 03-07-2010, 01:06 PM   #2 (permalink)
Favourite Bike: 70 Triumph T120R Bonnie
shrugger's Avatar
Other Motorcycle: 72 Norton Commando
Extra Motorcycle: Royal Enfield Bullet 500
Yep, it'll have to come off. Seems they should slide right out. But
they don't. Bit of a trick to it.
http://www.triumphrat.net/vintage-te...-stuck-on.html
"Thanks to denial, I'm immortal" -Phillip J. Fry
shrugger is offline   Reply With Quote
Old 03-07-2010, 01:08 PM   #3 (permalink)
Favourite Bike: 67 TR6C
looseparts's Avatar
Other Motorcycle: 06 Kawasaki VN900
Extra Motorcycle: 73 Yamaha DT3
yes - points and auto advance must be removed
Yes. The timing cover has a well or recess where the points and auto-advance unit are mounted and the cover will not come off until they are removed.
You can remove the points and whatnot with by unscrewing it them from the plate and the auto-advance can be knocked off its taper with a modest side-blow from a hammer (after its securing bolt is removed)
Send me a private message - I might know where you can get a parts manual and a shop manual.
looseparts is offline   Reply With Quote
Old 03-07-2010, 02:02 PM   #4 (permalink)
Thanks
Thanks guys for the tip!
This is my first Triumph and my first restoration project so I appreciate the guidance!!
Removing the Inner Timing Cover hason1980 Classic, Vintage & Veteran 0 11-21-2009 01:44 PM
1968 t100c charging issues ncapriot Classic, Vintage & Veteran 1 11-09-2009 12:32 PM
How do you remove the timing cover? Landshark Classic, Vintage & Veteran 3 07-17-2009 06:06 PM
Timing Cover Mrsinister Classic, Vintage & Veteran 1 03-11-2009 03:11 PM
