Steering head bearings questions
I have done a search of the tech threads and can't find any info or have missed it, so if it is already posted just direct me how to get to it.
I am putting together a custom job (old school chopper). Rigid frame, 1971 - TR6 motor, and it came with a 70's Triumph front end. The front end already had the tapered bearing conversion done, but I want to put a Springer front end on the bike. The springer (bought used) has a 1" shaft (no bearing came with it). The top bearing (dust cover and bearing as one unit) appears that it will work with the shaft, but I don't know what bearing to use for the bottom. The bottom bearing on the triumph stem was pressed on and cant be used on the springer as far as I can tell.
I am not a super mech, but I can turn a wrench pretty well. I just love to do my own work so I really feel like it is my ride.
All and any helpful advice will be appreaciated.
:confused
Here goes the rest of my money
