Timing Pinion postion? - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleMotorcycle.com Classifieds!Honda PowersportsMotorcycle.com
Vintage Technical Tips & Tricks Technical and maintenance tips and links
Old 12-13-2009, 09:48 AM   #1 (permalink)
Favourite Bike: only one I got t100C 71
Flatrabbit's Avatar
Hey guys! I had to renew my cam bushings on a 68 650 and I Forgot what postion the Pinions were in. Each pinion has three holes to allow it
to mount on the keyway on the end of the cam. how can I tell what keyway hole it needs to be in to ensure that when I line up my timing marks Ill be in the correct time! Thanks!
Shawn
Flatrabbit is offline   Reply With Quote
Old 12-13-2009, 10:04 AM   #2 (permalink)
Flatrabbit's Avatar
I promise I will never ask stupid questions like that again! I figured it was the keyway slot that lined up with the timing mark on the timing gear. I just dont understand why there are 3 holes??? of course Plewsy A.K.A the man A.K.A My Saviour (about 30,875 times) has a video for it. Plewsy God Bless you!
http://www.triumphrat.net/vintage-te...20r-video.html
Valve pinion timing marks HELP! Caulky Classic, Vintage & Veteran 47 06-19-2010 10:11 AM
Timing Pinion Nut Torque mutley72 Classic, Vintage & Veteran 9 08-23-2009 07:51 PM
73 trident cam pinion timing coloradobob Classic, Vintage & Veteran 1 08-17-2009 12:01 AM
More relaxed sitting postion beaman Twins Technical Talk 13 12-15-2008 10:20 PM
timing mark on crank pinion outsider Classic, Vintage & Veteran 12 06-06-2005 08:50 PM
