SportbikeTrackGear EPG MotoMotorcycle.comTriumph DetroitBritish Motorcycle GearRicor ShocksSoupy's Performance
Vintage Technical Tips & Tricks Technical and maintenance tips and links
Old 10-31-2009, 10:50 PM   #1 (permalink)
HID Headlight conversion T120R
Ok boys, some of you may think this a heresy but I converted my '70 Bonny to HID. This bike has been restored but its configured for my usage as a regular rider : mirrors, turn signals etc. It already had a halogen unit but that was slowly cooking the Lucas switches. The HID units are supposed to pull only 35 watts of power so my main motivation was to ease the load on the alternator.
I used one of the latest design H-4 conversion kits with the slim line ballast and separate striker along with the electromagnetic high/low beam solenoid. The halogen reflector works well in this case and the light output is amazing. Trundling down the road with this 40-year-old bike sporting better lighting than most modern bikes is ironic.
I suppose the current draw is less since I notice the wavering hand of the Lucas ammeter is fanning around much more in the "plus" zone now.
leafman60 is offline   Reply With Quote
Old 11-01-2009, 11:00 AM   #2 (permalink)
Favourite Bike: T120R Bonneville (mine)
Other Motorcycle: I wish
Hi leafman60
I fancied fitting HID to mine would you have a link for the unit you used?
cheers
Plewsy is offline   Reply With Quote
Old 11-01-2009, 12:06 PM   #3 (permalink)
Favourite Bike: T120RT
Other Motorcycle: T140V,T140D,T140E,T140J
yes more specific info would be appreciated.
KADUTZ is offline   Reply With Quote
Old 11-01-2009, 04:16 PM   #4 (permalink)
Hi guys. The unit I used was from www.xenonrider.com I already had an H-4 bulb and reflector so I ordered the H-4 HID kit. If you dont have an H-4 halogen headlight, you should probably get one of those first and fit the H-4 HID to it.
Xenonrider offers a plug-and-play kit for bikes. I imagine it has a diode or something to make the plug-and-play work. Its too technical for me to explain all that here except to say that it should work with your H-4 female connector that goes to the H-4 bulb. Id call or email them first and make sure the plug-and-play will work with a negative ground system aka Triumph. You may need to switch a couple of wires around in the connector.
They offer a "regular" ballast and a "slimline" ballast that is smaller. However, if you use the slimline ballast, you have an extra ignitor component in the works thats wired-in whereas the regular ballast has this integrated in the ballast. Is this sounding complicated ????
I didnt use the plug-and-play kit but wired mine up custom. I tied in the negative wire from the ballast to the same terminal on the headlamp switch that feeds the blue wire to the dimmer switch.
The positive wire from the ballast was grounded into the connectors collecting the other red ground wires in the headlamp shell.
This assures power to the ballast and HID once the headlamp switch is positioned all the way to the right in "on" position.
Next, I connected the electromagnetic solenoid wires from the HID 1. to the regular high beam terminal that used to feed the halogen bulb and 2. ground. Hence, the HID bulb burns all the time as long as the main light switch is on. The solenoid kicks it up to high beam whenever you trigger the dimmer switch to high.
Got that ? lol It aint that bad, once you get into it and think in reverse due to the positive ground.
I guess I need to try and post some pics for those who want to custom wire.
Old 01-13-2010, 12:13 PM   #5 (permalink)
Favourite Bike: 73 Bonneville kaf
Lucky Strike's Avatar
Other Motorcycle: 60 BSA c15
Yes please.
Also, I have a feeling that LED bulbs will be available for head lamp use in the near future. There is already a company that makes DOT approved LED headlights. 7" round units intended for use by big rig trucks. Theoretically you could just stuff one of these in your bucket, but they are very expensive. I think they are around $300.00 right now. And, they look very different that a stock headlight.
Fast. Cheap. Good. Pick any two.....
Lucky Strike is offline   Reply With Quote
Old 01-26-2010, 04:44 PM   #6 (permalink)
Im still working on those pictures.
By the way, when you do an HID conversion, if the bulb element comes with a reflector hood on it, Id remove it before fitting the HID bulb into your H-4 reflector. You get a better spread of more light. Mine is working well.
Old 01-28-2010, 07:46 AM   #7 (permalink)
By the way, I was able to easily fit all the guts and wires to the HID system inside the headlight shell of the '70 Bonneville. You do have to postion the bigger parts such as the ballast to fit around the master switch etc , but it will all fit with a little room to spare.
Old 01-29-2010, 11:22 PM   #8 (permalink)
As I tried to describe earlier, I used the solenoid-operated hi/lo, H-4, HID conversion. I wired it so that the ballast is powered by the main light switch on top of the bucket. The hi/lo solenoid is wired to be controlled by the thumb-operated handlebar dimmer switch.
I stuffed everything into the lamp bucket and didnt have to wrap the ballast or anything.
I need to do a photo illustrated version of this, I realise.
Old 01-30-2010, 12:07 PM   #9 (permalink)
Favourite Bike: '68 TR6R
68TR6R's Avatar
Other Motorcycle: 1978 suzuki 125
Which kit in particular did you purchase?
68TR6R is offline   Reply With Quote
Old 01-30-2010, 01:09 PM   #10 (permalink)
Favourite Bike: R3 Classic
Other Motorcycle: Bonnieville
Extra Motorcycle: KLR 650
While HID's draw a lower amperage than a halogen or incandescent (filament) bulb while running, they do draw quite a bit more amperage on start up. It takes a pretty stiff current to light off the bulb plus they don't like to be shut down and restarted in quick succession.
It's sort of like a flourscent tube light. It has to get to 'light off' temperature before it emits useable light.
If you have a bike with daytime lights (like the newer models), I suggest an inline switch to break the circuit while you start the bike. Ar some point the the near future, HID's will be displaced by LED headlights and as the technology advances they to will decrease in price, like the HID has.
With a minimum 20,000 hour lifespan, the LED units are the way to go. You'll never replace an LED unit and if it looses one diode in the cluster, you'll never notice the output difference.
The reason LED's are better is that they make little heat in operation plus it's instant on, with no warm up. The heat generated is amperage used.
You can fool some of the people all of time and all of the people some of the time..........
SidecarFlip is offline   Reply With Quote
Headlight Wiring - 69 T120R gaillarry Classic, Vintage & Veteran 9 10-14-2009 05:06 AM
Headlight conversion... RunsLikeAT-Rex Speed Triple Forum 19 07-30-2009 02:30 PM
HID headlight conversion anyone? wingnut Classic, Vintage & Veteran 5 11-23-2008 09:04 PM
HID headlight conversion on a S3 gaskinator5000 Speed Triple Forum 12 09-19-2008 11:05 PM
HID Headlight Conversion wildbillcu Twins Technical Talk 17 06-25-2008 05:08 PM
