whats that bolt? - Triumph Forum: Triumph Rat Motorcycle Forums
Vintage Technical Tips & Tricks Technical and maintenance tips and links
Old 10-20-2009, 07:36 PM   #1 (permalink)
Favourite Bike: 71 Bonneville
david_in_ky's Avatar
Other Motorcycle: HD ultra Classic
Extra Motorcycle: Hd Low Rider
whats that bolt?
Well here I go showing my newby ignorance..71 Bonneville, just reviewing tools and supplies needed before digging in to a mild rebuild
the cylinder bolt nuts are obviously 12 point ..but what ..is this the infamous whitworth ?..if so how are they sized and ignoring the preservation bit, why not replace with proper tensile hex nuts ? Know a good source for wrenches and sockets to handle ? thanks for any info..
[B]
Last edited by david_in_ky; 10-21-2009 at 03:54 PM. Reason: ANSWERED COMPLETELY THANKS
david_in_ky is offline   Reply With Quote
Old 10-20-2009, 10:42 PM   #2 (permalink)
Favourite Bike: '67 Triumph Bonneville
I believe a 1/2" 12-point box end will work if you grind down the outer edge to clear the gap.
I have, on a bike of my own, used standard 6-sided nuts on the cylinders.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 10-20-2009, 11:07 PM   #3 (permalink)
Favourite Bike: '68 TR6R
68TR6R's Avatar
Other Motorcycle: 1978 suzuki 125
Yep, 1/2 inch 12-point ground down. I believe snap-on has some wrenches that are for tight fits such as this, but I can't remember the number, and It is cheaper to buy a china wrench and grind it down. Probably cost you around three bucks.
68TR6R is offline   Reply With Quote
Old 10-21-2009, 06:57 AM   #4 (permalink)
whats that bolt
Thank you gentlemen, i believe a trip to my local flea market is in order....
[B]
Old 10-21-2009, 07:12 AM   #5 (permalink)
Favourite Bike: T140 E
you can't just rplace the whitworth nuts with Af as the thread will be wrong, so you'd need to remove the whole toip end to do the studs. That might mean rboring the block.
I'm sure that tyhere are guys in the states who can provide cheap whitworth tools.
Here, autojumbles (swapmeets) are full of stands selling tools for older bikes
DAVE M is offline   Reply With Quote
Old 10-21-2009, 11:24 AM   #6 (permalink)
You can replace the 12-point BSF nuts with 6-point BSF nuts.
GrandPaulZ
Born Again Bikes
My Photo album
Old 10-21-2009, 12:56 PM   #7 (permalink)
nuts!
I do plan on replacing the nuts with 6 point, will use similar tensile strength nuts
thanks to all who helped wise me up on this !
david
[B]
Old 10-21-2009, 03:38 PM   #8 (permalink)
Favourite Bike: 70 Triumph T120R Bonnie
shrugger's Avatar
Other Motorcycle: 72 Norton Commando
Extra Motorcycle: Royal Enfield Bullet 500
I ran over to Sears, picked up a $2 1/2" box end. So I wouldn't
be grinding on any of my good wrenches.
The 12 point nuts are readily availible. Just a matter of personal
taste, I suppose.
"Thanks to denial, I'm immortal" -Phillip J. Fry
shrugger is offline   Reply With Quote
Old 10-25-2009, 01:48 PM   #9 (permalink)
nuts
got lucky, stopped in my local flea market for a cheap wrench set and found a whitworth 5 pc set for $6.00..fits perfect no grind needed
[B]
Old 10-25-2009, 02:21 PM   #10 (permalink)
shrugger's Avatar
Outstanding!
I've never found anything but less than useless junk at any of those things.
Whats going on here? iceman Biker Hang-Out 12 06-19-2008 12:06 PM
whats this?? thumper017 Classic, Vintage & Veteran 5 04-21-2007 10:37 AM
whats going on here? iceman Biker Hang-Out 11 03-14-2007 05:09 AM
whats an R6 ORCA Speed Triple Forum 2 11-07-2006 01:08 AM
Whats between TOR and DD Indecis Twins Talk 9 01-17-2006 01:25 AM
