Oil pump & valve timing marks T120R (Video) - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Vintage Technical Tips & Tricks Technical and maintenance tips and links
Old 08-17-2009, 05:31 PM   #1 (permalink)
Favourite Bike: T120R Bonneville (mine)
Other Motorcycle: I wish
On returning home from a friends, a journey just over a 100 miles,
I did non stop and high speed where I could 70/80 ish! most of the way.
I digress, any way my oil light was flashing on and off on tick over,
so I set too , to have a look at the crank shaft oil seal and the oil pump.
While I was in the timing side I thought I would point out the valve timing marks and keyway positions.
Although I have got it running again, I have sent off for a Morgo pump
and two new seals, I will fit them as soon as they get here!
Anyway here's what I've been upto.
http://www.youtube.com/watch?v=yXGJfaPnI-o
valve timing marks and keyways on this one
http://www.youtube.com/watch?v=7eq3L4ddRCc
Only I can be guilty of cocking up the cam shaft oil seal,
OOooo! about 5000miles ago
Plewsy is online now   Reply With Quote
Old 08-22-2009, 10:53 PM   #2 (permalink)
the first one with sound
Sorry guys you tube took the sound off one of my vids.
music copyright stuff, so here is another upload of it.
http://www.youtube.com/watch?v=xj798...response_watch
Sorry for the hassle.
Old 08-31-2009, 04:13 PM   #3 (permalink)
Thanks, I could have def used this a while back......I'm sure you'll save someone the hassle I went through on my exghaust sprocket mis-alignment. (Lotsa kicks!)
"I like the way you talk, mmmm, hmmm." In my best Billy Bob Thornton voice..
boatwrench is offline   Reply With Quote
Valve pinion timing marks HELP! Caulky Classic, Vintage & Veteran 47 06-19-2010 10:11 AM
73 T140V Cam Gear Timing Marks LukeSmith1985 Classic, Vintage & Veteran 2 06-12-2009 03:38 PM
Valve Timing Marks T140V thirdbike Classic, Vintage & Veteran 7 05-09-2009 10:20 AM
Timing Marks ozjimmy T3 Sport / Touring Forum 2 03-02-2009 10:02 AM
help with 1967 T120R 650 timing gears el_nino3 Maintenance & Workshop Talk 3 08-02-2008 11:21 PM
