1976 Bonneville wheel building - Triumph Forum: Triumph Rat Motorcycle Forums
Vintage Technical Tips & Tricks Technical and maintenance tips and links
Old 07-04-2009, 01:56 PM   #1 (permalink)
Other Motorcycle: 1976 t140v Bonnie
Extra Motorcycle: xr 650
Hello 1st time posting here, I just put together some alloy rims and spokes, does anyone know the offset for the rear wheel or where to get the specs.
whatsthat is offline   Reply With Quote
Old 07-04-2009, 03:30 PM   #2 (permalink)
Favourite Bike: Triumph Bonneville
Other Motorcycle: Triumph Speedtriple
Hi there, welcome to the forum,
I'm not sure for the 76 (is it disc or drum brake?) The measurements I had for the offset for my rear wheel (72 T120R) were 2.0" (50mm) taken from the L/H side measured from the edge of the brake drum. As I said I'm not sure if the later models are the same.
Webby
Webby is offline   Reply With Quote
Old 07-04-2009, 07:47 PM   #3 (permalink)
Thanks Webby, mines a 76 t140v disc brake , I have wm4 (2.50) 18'' rim, the spokes are a really good fit there appears to be around 1/2" offset to the chain side.
Old 07-04-2009, 08:13 PM   #4 (permalink)
Hi Whatsthat,
In that case, I don't think my measurements will be of much use to you. My rear is a wm3. If no one can come up with a measurement (I'm sure someone out there can) You could fit the wheel to the bike with all the spacers etc. and then adjust the offset as required.
Good Luck
Webby
Old 07-06-2009, 08:20 PM   #5 (permalink)
problem solved the offset is 2.920" measured from the centre of th rim to the sprocket abutment face, thanks Kadutz.
Old 07-07-2009, 01:14 AM   #6 (permalink)
Favourite Bike: T120RT
Other Motorcycle: T140V,T140D,T140E,T140J
your welcome but what do you need scaned?
KADUTZ is offline   Reply With Quote
Old 07-08-2009, 11:32 PM   #7 (permalink)
I thought I may like to see that page,re the offset. I measured all that up and that is very close to the untrued dimension, canny George will be able to work with that, thats a very complicated hub set up also, being in three pieces I think it will need to be trued with the disc and sprocket in place..chances are once trued if you took the bolts out again it would never go back together.
Spoked wheel re-building jimmyj900 Maintenance Tips and Tricks for the T3 Classics 2 01-12-2010 06:00 AM
1976 Bonneville cooling/heat craka Classic, Vintage & Veteran 3 06-29-2008 03:42 PM
1976 Bonneville cooling/heat craka Twins Technical Talk 0 06-29-2008 07:48 AM
Bonneville Wheel Alternatives Brandon_Rice Twins Technical Talk 11 11-09-2007 09:39 AM
1976 Bonneville Klicker Classic, Vintage & Veteran 11 01-06-2005 08:14 AM
