Originally Posted by Plewsy
Hi trayden :-)
Its pretty common! the worst one for leaking on mine is the level plug.
I seal it with a few wraps of PTFE (thread tape) screw it in as tight as I dare
then I cover the head of bolt and surrounding case with a good gloop of silicon to stick it there.
Then I remove the case to drain oil and fill by measuring.
For the adjustment plug if the threads are not too damaged again a few wraps of PTFE around the plug also anneal the copper washer so it is super soft, or replace copper washer with a fibre one.
Don't take for granted this is where its leaking from though, as the plugs are about the lowest point on the case,
this is where oil seems to appear.
Thanks! It already has a fiber washer but i will try some PTFE!
Not sure myself where its coming from but doesn't leak when the bike is cold only hot!
I can leave standing for a week with no oil leak,as soon as i run it, it leaks!
Cheers,Den
