pre-purchase check list - Triumph Forum: Triumph Rat Motorcycle Forums
Vintage Technical Tips & Tricks Technical and maintenance tips and links
Old 06-25-2009, 06:50 AM   #1 (permalink)
As a veteran of three months Triumph ownership I have been asked to come and give 'expert advise' on a bike for sale by a friend.
I guess I will start with all the things that were wrong with mine, plus...
- frame straightness
- signs of collision
- welds in headstock
- tank leak
- engine and frame numbers (and their integrity)
- chain
- tracking
- smoking
- power availability
- braking
-shockers
...Anything to add?
cheers
derek
derek
Melbourne, Australia
71 T120RV
Progress blog - http://dirtystriumph.blogspot.com/
delrazor is offline   Reply With Quote
Old 06-25-2009, 08:58 AM   #2 (permalink)
Favourite Bike: '67 Triumph Bonneville
-Steering & forks - slop or klunking, oil seal leakage
-Hold front brake while holding front tire between your knees, pulling and pushing on handlebars will reveal bearing wear and/or slop by bike movement
-Clutch actuation - pull in lever & kick, should kick through freely
-Engine compression - kick should be quite firm
-Open seat, wiring should be fairly neat, no wire nuts or duct tape
-Swingarm bushings - Bike on centerstand, firmly push rear tire side to side, swingarm should not allow sidewards movement
-Brakes
-Tire condition
-Rear shocks - damping, signs of leakage
-Oil leaks
-Lighting & horn
-Ease of starting
-Tickover (idle) smoothness
-Shifting / clutch actuation
-Throttle response
-Ability to cruise at steady speed without surging
-Stability in turns and under braking
-Kill button
-837 other small things!
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Schedule Maintenance Check list nagibe Twins Technical Talk 19 03-31-2009 05:12 PM
Added new item to my pre-ride check list barneys Twins Talk 14 07-03-2008 02:10 AM
Exhaust...check, oil change...check, alarm...check rastataoist Triumph SuperSports 9 03-02-2007 07:17 PM
Where can I go to check a VIN on a possible purchase Howlin_955i Daytona Deliberations 2 01-26-2006 10:34 AM
