Cylinder head removal T120R (VIDEO) - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Vintage Technical Tips & Tricks Technical and maintenance tips and links
Old 06-23-2009, 10:55 AM   #1 (permalink)
Favourite Bike: T120R Bonneville (mine)
Other Motorcycle: I wish
In the shed again I am swapping the head because of loose exhaust stub and the valve guides have done a gazillion miles and I reckon they are passing way to much air/oil and are effecting the running especially tick over and slow running.
I am replacing it with the original head, which is unmodified, and has a small crack in it hopefully it will last a season
I wanted the inlet stubs out, but they do not need removing to take the head off.
http://www.youtube.com/watch?v=xNq9X_R8sB0
Plewsy is online now   Reply With Quote
Old 06-23-2009, 11:07 AM   #2 (permalink)
Favourite Bike: 1970 TR6 Spring Gold!
Nice video Plewsy. Thanks for sharing. What do you think happened to the timing side piston?
Hey, What's this oil on the floor?
quagmire is offline   Reply With Quote
Old 06-23-2009, 11:42 AM   #3 (permalink)
Thanks quagmire
As the bike has never had choke slides fitted the cable holes where blocked off... yes you guessed it a brass BA nut & bolt, "not fitted by me" It took twenty years for the nut to slacken when it did it dropped straight down the space in the throttle slide where the choke slide should be and got sucked straight in luckily I was just off tick over rolling in traffic when it went in, so it did not make many contacts before I MADE it stall What a clatter I thought I'd dropped a rod. Lucky! I was! didn't even bend a push rod,took the head off, removed the nut filed the high spots off things and then away. That was above five years ago
Old 06-23-2009, 01:44 PM   #4 (permalink)
Favourite Bike: Triumph Bonneville
Other Motorcycle: Triumph Speedtriple
Another nice vid Plewsy
Webby
Webby is online now   Reply With Quote
Old 08-07-2009, 09:56 AM   #5 (permalink)
When I took my head off the push rod tubes came off with the head and seem to be stuck in the head. I noticed that yours stayed on. How do I remove them from the head? Tap the top of the tube with a wood block?
wllgmr is offline   Reply With Quote
Old 08-11-2009, 01:38 PM   #6 (permalink)
Hi wllgmr, and welcome
sorry I took a while to answer, I've been rideabout
The pushrod tubes can stick either end, I use plenty of silicon on mine.
If they are stuck in the head grip them firmly and pull, wiggle and twist, they should come out ok!
How do I Re-torque Cylinder Head WHATHAVEIDONE Classic, Vintage & Veteran 21 04-28-2011 05:30 PM
removing cylinder base nuts `70 t120r alonzo Classic, Vintage & Veteran 15 06-16-2009 06:07 AM
Cylinder Block removal,Cylinder TDC ? argie Classic, Vintage & Veteran 2 05-04-2008 06:26 PM
Cylinder Head clive955 Tiger Chat 0 03-15-2006 03:54 PM
Cylinder head removal/reinstallation Osara Maintenance & Workshop Talk 12 03-30-2004 03:14 PM
