Setting valve tappets (VIDEO) - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Ontario TourismSportbikeTrackGearMotorcycle.comMotorcycle.com Classifieds!
Vintage Technical Tips & Tricks Technical and maintenance tips and links
Old 06-21-2009, 08:04 AM   #1 (permalink)
Favourite Bike: T120R Bonneville (mine)
Other Motorcycle: I wish
Hi all,
when doing stuff to my bike I have started to get my camera out, It makes doing the job twice as long to do, but hey!what the hell. The story behind them is me trying to cure a slight misfire at around 4000rpm, she has always run a bit rich and never liked ticking over, or doing 30mph.
So I started at the carbs (wrong) It seems to have turned out to be the OE Lucas Rita!
Ah! well its not the first time I have barked up the wrong tree, and sure it won't be the last.
Anyway here's me setting my tappets on my 1972 650cc T120R.
I use the settings 2thou" for inlets and 4thou" for the exhausts set when cold.
http://www.youtube.com/watch?v=AtZVwTXkyE8
Plewsy is offline   Reply With Quote
Old 06-21-2009, 09:45 AM   #2 (permalink)
Favourite Bike: Triumph Bonneville
Other Motorcycle: Triumph Speedtriple
Nice vid Plewsy
Webby
Webby is offline   Reply With Quote
Old 06-21-2009, 12:03 PM   #3 (permalink)
Favourite Bike: 1979 Bonneville
Plewsy,
Ah another fine video you got there. Still do not hear the
accent though.
GrandPaul,
Hey is there any way to get all of these video files into a
special section where people can reference them. It would
be of great help to those people who have not done these
operations before. A picture and in this case a video is much
better than one of us trying to discribe how it is done.
Pookybear
pookybear is offline   Reply With Quote
Old 06-21-2009, 12:14 PM   #4 (permalink)
Favourite Bike: '67 Triumph Bonneville
I'll move them to the tech section.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 06-21-2009, 04:47 PM   #5 (permalink)
Cheers webby Pookybear I'll try and mumble a bit louder next time
Thanks GrandPaulZ I wasn't quite sure where to put them
Old 07-07-2009, 10:22 PM   #6 (permalink)
Favourite Bike: '68 TR6R
68TR6R's Avatar
Other Motorcycle: 1978 suzuki 125
Plewsy,
It always seemed to me that 2 and 4 thou clearances was too tight, so I never set my lash to that, and have been using 4 and 6 thou. What are your views on rather tight clearance spec? It's not good to run valves too tight.
68TR6R is offline   Reply With Quote
Old 07-08-2009, 09:35 AM   #7 (permalink)
Hi 68TR6R,
You are spot on! with valves that are too tight! not good,
as it will cause valve and seat burning and a drop in compression,
and will make starting hard, when engine is hot.
I have always used the 2 & 4 thou settings given by Mr Triumph
Using the 4 & 6 thou settings maybe a little noisier but the increased service interval makes it worth while.
On well used machines the wear on the rocker arms and valve tops can make the use of feeler gauges almost impossible
as the feelers can bridge the dents in rocker arms giving a false reading,
in this case setting tappets (backlash) by FEEL is probably the most accurate way.
Old 07-08-2009, 04:49 PM   #8 (permalink)
Valve lash set too loose will beat up your adjusters and worse, the valve stem tips. You'll find the damage quickly, because the adjustment will loosen up even more quickly from the beating and banging.
2 & 4.
GrandPaulZ
Born Again Bikes
My Photo album
Old 07-28-2009, 02:12 AM   #9 (permalink)
jrn
awesome
This video just made my night, awesome job thanks a bunch!
jrn is offline   Reply With Quote
Old 07-28-2009, 11:24 AM   #10 (permalink)
Hi jrn and welcome to TR,
I am glad you found it helpful.
There is another way as well, If you get one inlet valve down you can set the other, and then the same on exhaust s 1 down set the other.
Valve springs and valve spring retainers jfn Twins Technical Talk 9 04-08-2009 10:16 PM
Tiger Tappets Tigerbob Tiger Workshop (archive) 11 10-20-2007 04:01 AM
valve/valve guide question GrayMitchell Classic, Vintage & Veteran 4 06-03-2007 02:22 PM
Just checked valve clearances - not waaay off! Any Valve Experts out there? ohiorider Twins Technical Talk 6 07-28-2006 11:37 PM
Noisy Tappets? thechopfather Classic, Vintage & Veteran 8 08-28-2005 09:17 PM
