Advance unit seems stuck on?!? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Vintage Technical Tips & Tricks Technical and maintenance tips and links
Old 06-18-2009, 10:28 AM   #1 (permalink)
Favourite Bike: 70 Triumph T120R Bonnie
shrugger's Avatar
Other Motorcycle: 72 Norton Commando
Extra Motorcycle: Royal Enfield Bullet 500
I haven't found any referance to removing it. I figured it
should just slide right out. Except it ain't!
Have I missed something? or some trick to it?
shrugger is offline   Reply With Quote
Old 06-18-2009, 11:06 AM   #2 (permalink)
Favourite Bike: '67 Triumph Bonneville
Notice that the then screw you removed goes all the way through the advancer into the camshaft.
Next, note that the advancer cam has a set of much thicker threads in it's end. Find a bolt that will screw into these threads, and screw it in at least 1/4".
Now, tap firmly on the screw from all four sides with the handle of a heavy screwdriver; that should pop it free. If not, tap with a small hammer or 2x4, NOT SO HARD as to damage the threads or bend the bolt.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 06-18-2009, 11:53 AM   #3 (permalink)
shrugger's Avatar
And there it is. Thanx
Old 07-25-2010, 11:48 AM   #4 (permalink)
Favourite Bike: '94 HD Softail Custom
Other Motorcycle: '69 Bonne w/71 bored mill
Oh yes!
I had the same problem. The screw and tap method worked like a charm.
This fgorum is a godsend.
Many thanks.
Bonnevivant is offline   Reply With Quote
Old 07-26-2010, 10:04 AM   #5 (permalink)
Favourite Bike: Rickman T120
Other Motorcycle: T160,TR6
Not so hard as to bend the AAU,more likely.Ever wonder why so many of these units are bent,and the points gap varies all over the place as you rotate the cam when the points are open.
A far better way is to use a longer bolt with a sliding weight (slide-hammer).Then you dont bend the AAU (too late already,for most Triumph owners).If the AAU doesn't get bent you still have 160 degrees dwell when the points are gapped to 0.015".
Mr.Pete is offline   Reply With Quote
Old 07-26-2010, 07:44 PM   #6 (permalink)
Favourite Bike: Triumph Bonneville
Other Motorcycle: Triumph Speedtriple
Another way!
The alternative to Mr. Pete's method is to put a length of stud in the hole with a diameter smaller than the hole and a length about 1 1/2 - 2" long. (If I remember correctly a M8 will work) Then find a bolt that screws into the advance cam.
The bolt in the cam will push on the stud, the stud will bottom out in the hole and will "push" the AAU off.
Sounds complicated but takes about 2 minutes to do, this is also the closest method to the "real" Triumph tool.
Webby
Webby is offline   Reply With Quote
Automatic Advance Unit Bill Jones Classic, Vintage & Veteran 1 08-05-2008 08:58 AM
T160 advance / retard unit needed jaguartvr Classic, Vintage & Veteran 8 05-14-2008 07:46 AM
Let me apologize in advance..but.. steveefer Classic, Vintage & Veteran 9 03-14-2008 10:32 PM
Lucas K2F manual advance stuck. Greaser Classic, Vintage & Veteran 3 02-18-2007 04:36 PM
Gotta have a *****,sorry in advance. bung1 Biker Hang-Out 20 02-04-2007 07:38 PM
