Oil Leak - Triumph Forum: Triumph Rat Motorcycle Forums
Vintage Technical Tips & Tricks Technical and maintenance tips and links
Old 05-30-2009, 12:15 AM   #1 (permalink)
Newbie
Other Motorcycle: GL1100
Extra Motorcycle: 87 Yamaha TW200
Oil Leak
I have a 79 T140E, It wasw given to me by a friend. It sat for at least 15 years. I had the top end overhauled by a local Triumph mechanic while I repainted the frame amd polished chrome.
Upon getting the engine back I threw it back in the frame, mounted it all up, and viola, oil dripping on the floor. This damn thing is like the USS Arizona. I got tied up on other projects and its been sitting for a year now, still leaking.
Anyway, It appears to be comeing from the kick-starter. Is this a common occurence, or at least not a freak thing? And how would one fix the issue? I do have an old manual but i would rather get sound advice from you who have experience.
Any advice would be greatly apprecited.
Stuck
79 T140E
Earth first, we can ride on the other planets later.
stuckthrottle is offline   Reply With Quote
Old 05-30-2009, 10:56 AM   #2 (permalink)
Favourite Bike: '67 Triumph Bonneville
The kickstart shaft uses a bushing that you'll need to replace. You can drive out the old one with a properly sized socket after heating the cover in an oven at 250 for 10 minutes, it should almost FALL out.
When you turn on your oven to pre-heat it, wrap the new bushing in plastic food wrap and set it in your ice tray in the freezer, buried in ice.
After popping out the old bushing, while the cover is still hot, pop the new one out of the freezer and simply tap it in SQUARELY with a plastic hammer or very gently with a regular hammer.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 05-30-2009, 02:12 PM   #3 (permalink)
Newbie
so i need to remove the engine and split it then right? how difficult is that? I've never done that. I'll be honest, it does intimidate me.
Stuck
79 T140E
Old 05-30-2009, 02:23 PM   #4 (permalink)
Favourite Bike: '68' T120 Bonneville
Other Motorcycle: 2006 T100 Bonneville
Extra Motorcycle: '79' T140 street tracker
You just have to remove the outer cover the kick start shaft is sticking out of. It can be done with the engine in the frame. Not a tough job. Change the seal while you're in there. I think yours also used a gasket under the outer cover.
jimmy bush is offline   Reply With Quote
Old 05-30-2009, 03:41 PM   #5 (permalink)
Newbie
That's a relief. I should.ve looked at it, i would have figured it out. I'm on my way to the parts house today so I will pick up some gaskets and seals.
Stuck
79 T140E
Oil Leak! TRI-AL Classic, Vintage & Veteran 4 06-17-2008 07:40 AM
Another oil leak Schmitty Triumph SuperSports 8 01-10-2006 08:46 PM
Oil Leak mrgadget Twins Talk 5 08-13-2005 04:45 PM
Anybody else had an oil leak? Yogi The Rocket Science Forum 7 08-01-2005 05:23 PM
Now I have an oil leak !!! Paul1227 Tiger Workshop (archive) 3 07-25-2005 05:53 AM
