Disassembly Tip / Advice - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!New BonnevilleMotorcycle.com
Vintage Technical Tips & Tricks Technical and maintenance tips and links
Old 04-30-2009, 11:29 AM   #1 (permalink)
Favourite Bike: '67 Triumph Bonneville
Just read a thread about a "spare" shim washer after an engine rebuild and it occurred to me to remind y'all that when you disassemble a bike, engine or component, to have the parts book handy and check the parts as they come off. That way, you'll be somewhat familiar with where the various bits go when its time to put them all back!
It also helps to understand what might have been the cause of various failures if the person previously working on the bike/engine/component installed things wrong or left out miscellaneous bits (shims are notoriously overlooked).
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 04-30-2009, 01:21 PM   #2 (permalink)
Favourite Bike: '78 Triumph T140E
Other Motorcycle: '07 Ducati ST3S
Extra Motorcycle: '68 BSA B44B
Yes, most helpful. I can't tell you how much time I've wasted trying to figure out why things don't fit as well going together as they did coming apart. Spacers/shims are critical. Thanks.
As it is, Andy
'78 Triumph Bonneville T140E
motersikelist is offline   Reply With Quote
Need Help: Tach disassembly Dumluk Hinckley Classic Triples 3 01-12-2009 11:21 PM
truxton fork disassembly britts and beemers Twins Technical Talk 2 08-13-2008 07:11 PM
Need help with fork disassembly rminchi Twins Technical Talk 11 03-26-2008 09:45 PM
Disassembly of F3 Forks? Hawk Twins Talk 6 10-14-2005 10:39 AM
SSSA disassembly question bridgestone175 Sprint Forum 7 08-19-2005 12:15 PM
