Sounds Fun,
The crankshafts should be interchangeable between the 650 & 750, but I think you would need to use the original primary drive due to the duplex chain on the 650 & the triplex fitted to the 750 (the crank may be slightly longer, anyone out there who could confirm
As for the rest I figure it should fit.
Good luck
Webby
