Another heavy-vs-light flywheel argument - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.com Classifieds!Motorcycle.comHonda Powersports
Vintage Technical Tips & Tricks Technical and maintenance tips and links
Old 04-20-2009, 10:54 AM   #1 (permalink)
Favourite Bike: '67 Triumph Bonneville
(asked in a PM)
This all goes to your intended use.
For racing, lighter is better.
For everyday road use, heavier is better.
In racing, you want the engine to have fast response and spin up to high revs very quickly. Lighter flywheel allows the engine to spin very freely on accelleration, and drop revs very quickly on decelleration (for engine braking effect). Normal decrease of efficiency in engine tuning (carb, plugs, points & valves) over time is magnified and amplified in free-spinning engines; so, you must keep it in finer tune or it will be more quickly noticeable.
On the street, you want the engine's intertia to remain as constant as possible for smoothness at idle and typical road speeds. A heavy flywheel requires less throttle at idle and gives a more predictable feel on accelleration and decelleration. A steady spinning heavy-flywheel engine is somewhat more forgiving of normal decrease in efficiency over time; you won't notice the need for minor valve adjustment or new plugs until it's more pronounced.
That's my additional 2 cents...
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 04-20-2009, 02:07 PM   #2 (permalink)
Tiger Dale's Avatar
I totally agree.
TD
Tiger Dale is online now   Reply With Quote
Old 04-20-2009, 02:28 PM   #3 (permalink)
Favourite Bike: '68' T120 Bonneville
Other Motorcycle: 2006 T100 Bonneville
Extra Motorcycle: '79' T140 street tracker
Unless of course you like your street bike to have the lively response of a race bike. I might be a crazy old fart but I'd like mine to be able stand straight up if I wack the throttle too hard. It won't of course but I'd like it if it could. There is some guy on the Hinkely twin forum that is getting 112hp at the rear wheel of his New Bonneville. The bike is supposedly docile enough to be comfortably ridden on the street unless you get crazy with the throttle, then you'd better be hanging on. I think that thing would be a gas to own/ride. I would like to do some of his mods to my T100, maybe about 80 rwhp worth but that's just me. (Hey, you said is was for argument didn't you?)
jimmy bush is offline   Reply With Quote
An argument for Loud Pipes BeHereNow Biker Hang-Out 43 11-28-2008 02:50 PM
An argument for keeping some of the Thruxtons flaws. SubCom Club Cafe' 12 10-06-2008 03:24 PM
360 degree flywheel trboam Twins Technical Talk 0 08-12-2008 09:53 PM
Argument about shocks MotoBuddha Twins Technical Talk 10 06-20-2008 09:40 AM
