Cylinder Bore Tolerances - Triumph Forum: Triumph Rat Motorcycle Forums
Vintage Technical Tips & Tricks Technical and maintenance tips and links
Old 04-08-2009, 04:31 PM   #1 (permalink)
Favourite Bike: 1968 500 Flat Tracker
BuckeyeRat's Avatar
Other Motorcycle: 1961 T120C
Extra Motorcycle: 1969 Bonneville
I just measured my cylinder bores with a dial bore gage and I'm getting 2.831" left cylinder and +.0005" larger on the right.
I'm not concerned about the difference but rather the size of the bore themselves.
According to the Clymer manual a .040" over std. bore for a 650cc should be 2.8348"-2.8353"
Note that I have not yet pulled the block off yet to measure the pistons themselves but should I be concerned with the measurement I'm getting? The bores look nice, no scrapes or scuff marks so I'm reluctent to pull the block if I don't have to.
Could use some clarification from you pro's out there.
Thanks,
Al
BuckeyeRat is offline   Reply With Quote
Old 04-08-2009, 05:30 PM   #2 (permalink)
Favourite Bike: all of them.
Other Motorcycle: two 500's, T100R, T100C
Extra Motorcycle: TR6R
that's interesting.
coupla things come to mind:
have you compared your Mikes to a check block?
the best machineists i've had want the pistons before they bore, could you have had some strange pistons that had to be fitted?
Sunshine Jim is offline   Reply With Quote
Old 04-08-2009, 05:51 PM   #3 (permalink)
BuckeyeRat's Avatar
That's the first thing that came to mind is that I set up the dial bore gage incorrectly so I double checked the setting master and triple checked the bores again with a telescopeing gage.
Same size as with the bore gage.
I plan on pulling the cylinder block off and measure the O.D. of the pistons and check ring gap to see if everything is within spec.
If not I'll just put a 750cc kit on it.
Old 04-08-2009, 06:04 PM   #4 (permalink)
ya
just to be exact as to my meaning,
occasionally a mike and especially the 2 inch plus will be off a few thou.
my machinist lets me use his check blocks. a small chunk of steel that's right on the money like these. Have you checked your outside 2 to 3 inch lately?
http://toolmonger.com/2009/02/20/pre...-gauge-blocks/
Old 04-08-2009, 06:55 PM   #5 (permalink)
yup!
I see. You'd see if one or the other was off by comparing the two.
They gave you the same readings is what you mean or close enough at any rate.
Bet it's an off stock piston set when you get them out. Makes you wonder how many piston sets are that far off the manual boring sizes. A little time with a new set of pistons and a sunnen hone sould have ya smiling.
Old 04-08-2009, 07:36 PM   #6 (permalink)
Favourite Bike: '68' T120 Bonneville
Other Motorcycle: 2006 T100 Bonneville
Extra Motorcycle: '79' T140 street tracker
The pistons vary in size. A machinist that knows what he's doing won't just bore the cylinder without having the pistons to insure getting the right skirt clearance. The rings come a bit big to allow them to be trimmed to fit after a bore job .
jimmy bush is offline   Reply With Quote
Old 04-09-2009, 10:05 AM   #7 (permalink)
Favourite Bike: '67 Triumph Bonneville
Half a thousandth between bores is not uncommon, especially if the last work done was a simple honing with new rings.
I sure wouldn't be worried, unless the pistons are marred, you are experiencing low compression, and/or smoking.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 04-16-2009, 07:27 PM   #8 (permalink)
BuckeyeRat's Avatar
Update
I pulled the block off and took it to work and again measured 2.831
with a SUNNEN dial bore gage in the bores. (no need to put it on the CMM) To make matters even worse the piston O.D.'s are 2.825 max. on one and .8195 on the other. Also found out the tappet od's are out of tolerance too.
No doubt I will rebore/hone to the the proper tolerance and buy a new set of pistons/rings/pins.
What is a good set of pistons to use for these bikes?
Old 04-17-2009, 01:22 AM   #9 (permalink)
I use JCC which are re-branded as Emgo, Cycle Craft and other names.
Use .0045 clearance on the cylinders, and .010 end gap on the rings. (Take the new pistons to the machine shop BEFORE boring and final honing).
GrandPaulZ
Born Again Bikes
My Photo album
Old 04-17-2009, 01:41 AM   #10 (permalink)
Favourite Bike: '05 T100
Well... you just did what I was going to post that you do... check piston 'diameter'.
I just rebuilt a Massey Ferguson diesel tractor (also British) , new pistons, new sleeves etc. The bore dia was a half thousanth under tolerance according to the book .... but the pistons were about a half thousanth under too so I knew I still had proper skirt clearance.
It looks like you are going the right way though... good luck with this...
Geimer is offline   Reply With Quote
650 tiger cylinder bore questions????? bobberguy0341 Classic, Vintage & Veteran 8 02-02-2009 01:18 AM
Chain adjustment tolerances Lion Twins Technical Talk 28 08-31-2007 07:29 PM
valve tolerances - opinions? DrPat Twins Technical Talk 16 01-31-2007 04:30 PM
Front Bore Master Cylinder Britrover Twins Talk 0 08-08-2005 03:14 PM
Triumph 650 big bore cylinder panic Classic, Vintage & Veteran 5 12-13-2004 10:54 PM
